Other Classic Rebuilds
Some rebuild pix - preliminary
Topic: Some rebuild pix - preliminary (Read 2596 times)
January 31, 2005, 01:51:39 PM
Read 2596 times
Wilson
January 31, 2005, 01:51:39 PM »
A couple of rebuild pix. This is from a friend's rebuild. It may give some insight to those wondering whats under their deck. Apparently there were many different versions of the same boat, so there are no guarantees that it will be exactly the same. This one had glass over foam stringers. The foam was soaked with water.
Wilson Ayala
Tampa, FL
January 31, 2005, 02:12:42 PM
Radioshop
January 31, 2005, 02:12:42 PM »
Wow, now that's a mess! What year was that boat?
Miamuh, Florida
January 31, 2005, 02:17:41 PM
Wilson
January 31, 2005, 02:17:41 PM »
'79 I have more. It came together nicely. I need some of it finished, now that it is finished.
Wilson Ayala
Tampa, FL
January 31, 2005, 02:52:14 PM
captin.kid
Guest
January 31, 2005, 02:52:14 PM »
what size???
January 31, 2005, 03:02:43 PM
Radioshop
January 31, 2005, 03:02:43 PM »
I gotta tell you, as wierd as this sounds, if my boat was that far knocked down, I'd have to serously consider turning her into an inboard. Why not? You'd need to build new decks and, you could do whatever you wanted with the stringers at that point.
Miamuh, Florida
February 01, 2005, 12:42:57 PM
Wilson
February 01, 2005, 12:42:57 PM »
He is looking to go fairly shallow. There is a porta bracket on the back now too.
Its a 222
Wilson Ayala
Tampa, FL
February 04, 2005, 07:58:03 AM
Seadog
February 04, 2005, 07:58:03 AM »
Wilson - no offense but are you sure that hull is an Aquasport? The hull, deadrise looks too deep and the stringers are different. That may be an AS knock-off.
1970 Aquasport 222
Spring Hill, Fl.
February 04, 2005, 08:19:49 AM
Wilson
February 04, 2005, 08:19:49 AM »
Good eye. It is a knock off. My friends who bought it didn't even realize until they had pulled it completely apart. I'm sure someone made a plug out of an Aquasport, and built that boat.
In reality it is so similar you would never know. I know that the 222 changed almost every year during the 70s.
In the early 70s there was no dead rise, but as the years progressed, the deadrise grew. So in 70 you would have had a flat back and in 76 you would have about 12deg. deadrise.
Wilson Ayala
Tampa, FL
