Author Topic: 170 bow eyre replacement  (Read 713 times)
April 19, 2015, 08:19:54 AM
Read 713 times
Sosrbny
« on: April 19, 2015, 08:19:54 AM »
I'm sure this has been discussed and I have searched but I can't find my answer. i  am asking for help. My bow eye cracked on 170 aqua sport 1976 hull. What is the best place to cut in order to reach the bolts? Anchor locker,deck,or inside storage box in bow?
Any help would be appreciated
April 19, 2015, 08:59:27 AM
Re: 170 bow eyre replacement
« Reply #1 on: April 19, 2015, 08:59:27 AM »
The eye is located just below the anchor locker (as you know) - I think I would cut a pie plate into that area.
That being said, it still won't be real easy to work on. If you can cut a pie plate into the front wall of the fishbox also, then you'll be able to do the work with both hands
April 19, 2015, 09:50:18 AM
Sosrbny
« Reply #2 on: April 19, 2015, 09:50:18 AM »
Thanks for the reply. I like the idea of the second hole in the fish box. I'll start with the one in he locker and see from there. Thanks again
April 19, 2015, 04:55:17 PM
« Reply #3 on: April 19, 2015, 04:55:17 PM »
That's going to be the tough one to cut. I cut mine in the material before I glassed it in so it was easier.
April 20, 2015, 11:32:23 AM
« Reply #4 on: April 20, 2015, 11:32:23 AM »
Don't know if you saw this. Different model, same concept:
http://classicaquasport.com/smf/index.php?topic=10147.0
More thoughts:
http://classicaquasport.com/smf/index.php?topic=7633.0
Good luck. :thumright:
