Author Topic: Formula 23 - shine  (Read 1820 times)
June 25, 2015, 01:34:32 PM
Shine
Re: Formula 23 - shine
« Reply #15 on: June 25, 2015, 01:34:32 PM »
The shape of this transom does not make for an easy core application, I was looking at putting in 2 x 3/4" transom foam int he i/o bump, followed by a third layer across the whole (curved) transom. Knowing how much putty, grinding, mess that is going to be I have been thinking of a better way
I am considering going with a poured transom for this boat. I have always disliked the pour transoms,most of the time they are used as a short cut and you can never ensure a good bond. In this case I am able to ensure a bond (all the old outside skin has been ground). Plan would be to tab (glass around outside) a piece of transom board straight across the back, brace it, then pour a ceramic reinforced transom. Then a new inside glass skin would be put in. Finial thickness will be substantial, well over 3" in the center. Besides a little extra wait, and cost this might be the best option for this boat.
I may fill the I/o bump with transom foam before pouring, that would save weight and cost.
I may go with twins on this boat, so the added transom strength would be welcome
shot of the transom, almost ready for a new core ...
June 25, 2015, 02:13:09 PM
Callyb
  • MidWest
« Reply #16 on: June 25, 2015, 02:13:09 PM »
Joel, If you are going with an outboard why would you just cut it out and build it back in flat?
Carl
___________________________
June 25, 2015, 02:33:00 PM
Shine
« Reply #17 on: June 25, 2015, 02:33:00 PM »
Carl,  That is not a bad idea, and I think I would do it except for the added work.
If I did, i would add 2' to the hull though  :mrgreen:
I also really like the curved transom.
June 25, 2015, 02:43:30 PM
Callyb
  • MidWest
« Reply #18 on: June 25, 2015, 02:43:30 PM »
The 2' thing crossed my mind last night, beer in hand of course. :97:
Carl
August 01, 2015, 10:37:29 AM
Shine
« Reply #19 on: August 01, 2015, 10:37:29 AM »
I have decided to build a custom boat instead of rebuilding this one, so the hull is for sale.  Any reasonable offer.  Trailer can be included, but its not in good shape, really only good for moving the hull around (bent axle).  I will include a wholesale discount on materials used to rebuild her.  PM or email with any questions.
Joel
