Author Topic: Bronze Thru Hulls  (Read 384 times)
April 07, 2015, 02:06:30 PM
Read 384 times
Mullady76
Bronze Thru Hulls
« on: April 07, 2015, 02:06:30 PM »
I will be keeping my boat (200CCP) in a slip this year and I was wondering if need to do anything special to the bronze thru hulls for the scuppers.  As most of you know the thru hulls are under water on this boat.  Do they need to grounded or tied into something with an anode?  Can I bottom paint right over them to prevent marine growth?
Thanks, Sean
April 07, 2015, 02:28:12 PM
Re: Bronze Thru Hulls
« Reply #1 on: April 07, 2015, 02:28:12 PM »
I'm assuming you are referring to the deck drainage which exits just above (when new) the waterline in the rear section of the hull.
On my 84, they were plastic. I kept my hull in the water for a year but they were out (except maybe when the boat rocked while moored).
This is the first time I recall anyone asking about bonding them. The seacock (raw water pickup) yes but not the thu hulls.
Glancing at several CCPs it appears those with bottom paint did cover them so you should be fine on that point.
This should be interesting.
April 07, 2015, 04:38:15 PM
Mullady76
« Reply #2 on: April 07, 2015, 04:38:15 PM »
Capt. Bob, I replaced them with heavy duty bronze ones when one of the original plastic fittings cracked. I should have said the fittings are partly submerged from the wet wood and foam. I know the raw water pick up / seacock gets bonded, that's why I asked about the drain fitting.
April 07, 2015, 04:50:26 PM
« Reply #3 on: April 07, 2015, 04:50:26 PM »
Well when you want the truth, the whole truth and nothing but the truth you go to The Hull Truth :roll:
Here's an interesting read to get you thinking.
http://www.thehulltruth.com/boating-forum/324002-bottom-paint-corrosion-around-thru-hulls.html
Yet another.
http://www.thehulltruth.com/boating-forum/10586-bonding-above-waterline-thru-hulls.html
Yet another thought on bonding.
http://www.pennyanbbs.org/index.php?showtopic=624
Good luck and if you do decide to bond, a photo or two would be greatly appreciated. I'm thinking this will come up again someday.
Thanks and good luck. :thumright:
May 06, 2015, 10:55:31 AM
bac0701
« Reply #4 on: May 06, 2015, 10:55:31 AM »
i installed an 1 1/4 '' in my osprey last night. ordered it online and made the flanging tool from something i saw on the hull truth. 3/4 bolt and some washers... i could not find a rounded nylock nut to start the flanging. i ended up doing it with a hammer and something found in the garage. then i put the bolt in and tightened with washers. Came out pretty good for my first time. also put some 5200 in there to seal it
