Author Topic: has any one ever moved there center consol forward  (Read 400 times)
April 02, 2015, 10:23:49 AM
Read 400 times
baby1
« on: April 02, 2015, 10:23:49 AM »
has any one ever moved there center console forward ? from stock  location ?
April 02, 2015, 12:02:25 PM
Re: has any one ever moved there center consol forward
« Reply #1 on: April 02, 2015, 12:02:25 PM »
Of course, usually when they are trying to offset a heavier engine or a bracket addition or more batteries in the aft, etc.
Just to do it because you want more room in the aft, be careful, you'll change the Center of Gravity of the boat.
April 02, 2015, 12:41:12 PM
baby1
« Reply #2 on: April 02, 2015, 12:41:12 PM »
thanks//// ill move it 5 inches or so // just give me a bit more  room  :13:
April 02, 2015, 01:06:40 PM
« Reply #3 on: April 02, 2015, 01:06:40 PM »
Remember that the boat was designed with a specific CoG and the console/fuels tank and possibly batteries were placed in the console at the CoG. Unless you're going to offset the CoG a little in the aft with some added weight the boat will handle differently and be bow heavy  :huh02:
April 02, 2015, 05:07:13 PM
« Reply #4 on: April 02, 2015, 05:07:13 PM »
Several folks have moved the console forward a bit to make more space aft.  Aquasport actually did this on the last version of the Osprey - if you look at the 2005 (last model year) 255 - you can see how far forward the console is.  The ride gets worse when you move the console forward, and CG can be an issue, especially if you have 2-3 batteries under the console.  The 255 is nice for trolling and fishing from the back, but there is very little room up in the bow area:
April 03, 2015, 02:45:09 PM
williecoyote
« Reply #5 on: April 03, 2015, 02:45:09 PM »
I moved the console forward on my old boat to "trim" her out, She was stern heavy.
The side benefit was more room aft.
April 04, 2015, 07:33:16 PM
Shine
« Reply #6 on: April 04, 2015, 07:33:16 PM »
something else to consider is the weight of the people you move forward when you push the console up.  If your hanging a heavy engine or putting it on a scissor style bracket I would absolutely move weights to offset this (tanks. baitwell, console,etc).  If you know where you current CG is located, you can make a simple spreadsheet that tallies the moments fore/aft of the moved weights
