Author Topic: Gas tank replacement 170  (Read 1979 times)
March 31, 2015, 12:57:48 PM
Reply #45
Martin t
Re: Gas tank replacement 170
« Reply #45 on: March 31, 2015, 12:57:48 PM »
Yes the tank is out in my garage next to woodstove thawing outThe previous owners must have filled the tank with waterfor ballast I thinkThe pick up two is broke off of the fitting because it goes down and then makes a 90° turnthrough a hole in the baffle towards the back of the tank
Marty
March 31, 2015, 08:40:59 PM
Reply #46
« Reply #46 on: March 31, 2015, 08:40:59 PM »
Martin,
If that's the original tank you may want to reconsider and replaced it with a new tank. Can you see the manufacturer's tag on the tank?
April 01, 2015, 05:15:33 AM
Reply #47
Martin t
« Reply #47 on: April 01, 2015, 05:15:33 AM »
The only thing on tank is on bow side written with green sharpie tp26/27gal
Marty
April 02, 2015, 06:23:55 PM
Reply #48
Martin t
« Reply #48 on: April 02, 2015, 06:23:55 PM »
Had tank cleaned and tested a radiator shop no leakes and every thing looks good
Marty
April 02, 2015, 06:31:43 PM
Reply #49
Martin t
« Reply #49 on: April 02, 2015, 06:31:43 PM »
Just trying to save money there to put into a knew console and gauges maybe  :think:
Marty
April 05, 2015, 06:34:14 AM
Reply #50
Martin t
« Reply #50 on: April 05, 2015, 06:34:14 AM »
Decided to have knew tank built and am going to move pickup and sending unit to back of tank
Marty
April 05, 2015, 11:22:48 AM
Reply #51
« Reply #51 on: April 05, 2015, 11:22:48 AM »
Very good.
I think you'll feel a lot more comfortable with this investment and you can start with a clean fuel system and hopefully avoid future contaminated fuel problems that are common this days.
Good luck and post up your progress. :thumright:
April 05, 2015, 11:43:05 AM
Reply #52
Martin t
« Reply #52 on: April 05, 2015, 11:43:05 AM »
Thanks bob check out my pic in the transome cost colum let me know whatcha think
Marty
May 02, 2015, 08:23:05 PM
Reply #53
Martin t
« Reply #53 on: May 02, 2015, 08:23:05 PM »
My friend is almost done with tank moved pickup and sending unit to back and filler and fent toward 4 inches to get better hose, now he want to no if I want him to make me a 1/4 inch diamond plate coffin cover what do you guys think, I think it would look pretty good
Marty
May 04, 2015, 09:14:17 AM
Reply #54
« Reply #54 on: May 04, 2015, 09:14:17 AM »
Martin,
The "look" is up to you. That stated, I think you will find that the aluminum will get very hot in the sun. If you like pacing the deck barefoot, you may find this area uncomfortable.
Just a thought.
May 04, 2015, 09:28:07 AM
Reply #55
« Reply #55 on: May 04, 2015, 09:28:07 AM »
My $.02 - I think it would look like a ....well... a hatch cover.  Like someone made it as an after thought instead of being part of the design.  Also agree with CB about the heat.  The regular floor will get warm enough in some instances, the aluminum will get scorching.
May 04, 2015, 10:53:29 PM
Reply #56
Georgie
« Reply #56 on: May 04, 2015, 10:53:29 PM »
Quote
  OMG NOOOOOOOOO!!    :confused1:  I realize you're in Durham CT and I'm in South Florida, but I grew up in Guilford so I fished the same waters.   :tme:  The diamond plate will get CRAZY hot in the summer sun, and it will also be VERY slippery when wet.  Stick with fiberglass and gelcoat unless you want to buy one of those custom but expensive covers to protect your feet.  Many of the members here have just re-cored their covers to fix any waterlogging or weaknesses.  It's a pretty darn easy project and takes no more than a weekend of your time.
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
May 05, 2015, 08:52:43 AM
Reply #57
« Reply #57 on: May 05, 2015, 08:52:43 AM »
One of my favs. Still lookin' for the anvil.
http://classicaquasport.com/smf/index.php?topic=4360.msg27958#msg27958
Here's another.
http://classicaquasport.com/smf/index.php?topic=6907.msg49957#msg49957
Good luck. :thumright:
May 11, 2015, 03:48:22 PM
Reply #58
Martin t
« Reply #58 on: May 11, 2015, 03:48:22 PM »
Never even crossed my mind about the heat glad I asked, as for south Florida you can have those alligators and bugs
Marty
June 07, 2015, 12:11:12 PM
Reply #59
Martin t
« Reply #59 on: June 07, 2015, 12:11:12 PM »
Knew gas tank all in coffin cover fixed now trying to figur out wiring what a mess :wtf01:
Marty
