222 CCP Rebuilds
222 CCP Cockpit Trim
Topic: 222 CCP Cockpit Trim (Read 1188 times)
March 10, 2015, 06:03:33 AM
Read 1188 times
Woodeneye
March 10, 2015, 06:03:33 AM »
Hi guys...does anyone know here I can hold of the edge trim used in the cut out in the cockpit sides? Its a molded plastic with a coiled metal insert laid into the plastic. Like in the photo. Mine is shot/missing/rusted out.
Thanks in advance.
March 10, 2015, 08:33:29 AM
Global Moderator
Re: 222 CCP Cockpit Trim
March 10, 2015, 08:33:29 AM »
Wood,
This group makes all types of marine trim.
http://tacomarine.com/cat--Trim-Moulding--trim.html
They may have made what you currently have so look through the site and see if you can match or at least find a product that works. You then may need to purchase from a dealer like this.
http://www.starmarinedepot.com/taco-flexible-vinyl-trim-3%2F8%22-opening-x-5%2F8%22w-x-25%27l-white.html?gclid=Cj0KEQjwrPqnBRD56dGe1o_WlZsBEiQAb5ugt0SL36H2-ycayBUya4OFM5_O9XqVmEM6hDRF2sQl7xEaAjFs8P8HAQ
March 10, 2015, 09:37:00 AM
Georgie
Mechanical Master
March 10, 2015, 09:37:00 AM »
This may help. Trimlok is the manufacturer that uses the flexible metal interior within the trim.
http://www.trimlok.com/?wm_crID=20491965&wm_lpID=32004403&wm_ctID=71&wm_kwID=19469459&wm_mtID=2&wm_content=0&wm_g_crID=40077297411&wm_g_kw=trim+lock&wm_g_pcmt=&wm_g_cnt=0&wm_g_device=c&gclid=CPya05jzncQCFeFj7Aodv0gADg&wm_kw=trim+lock
Shorter lengths are available on e-bay once you identify the exact product you might want. Bought some myself for my anchor and console hatches.
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
March 10, 2015, 10:15:01 AM
Mechanical Master
March 10, 2015, 10:15:01 AM »
Many choices - buy it by the foot or just buy a roll and use it when you need it:
http://www.ebay.com/sch/i.html?_odkw=boat+edge+trim&_from=R40%7CR40&_osacat=6000&_from=R40&_trksid=p2045573.m570.l1313&_nkw=boat+edge+trim+white&_sacat=6000
March 10, 2015, 09:26:45 PM
Woodeneye
March 10, 2015, 09:26:45 PM »
Unreal. Thank you people.
March 11, 2015, 08:18:41 AM
Global Moderator
March 11, 2015, 08:18:41 AM »
Quote from: Woodeneye on March 10, 2015, 09:26:45 PM
Unreal.
The Forum................................................or the trim?
222 CCP Rebuilds
