Author Topic: 22 Flatback /// 150 yamaha Prop ?  (Read 444 times)
February 17, 2015, 03:50:53 PM
Read 444 times
c bishop
« on: February 17, 2015, 03:50:53 PM »
Got a 22 Flatback , open transom ,  150 Yamaha Four Stroke (25inch) on a  6inch jackplate.  What prop would yall suggest for the boat ? Three blade ? Four lade ?
-Cody
February 18, 2015, 08:11:26 AM
Jack Hart
Re: 22 Flatback /// 150 yamaha Prop ?
« Reply #1 on: February 18, 2015, 08:11:26 AM »
My 1971 flatback with original open transom runs with a 20" shaft 150 hp Evinrude Ocean Pro mounted on a 6" jack plate.  The prop I'm running is a stainless SST 3-blade 14-3/4 x 17.  WOT I'm nudging 40 mph and the hole shot is excellent.  The prop runs with very little slip jacked up 3" and jacked to 6" slips more but will still get out of the hole easily. I see from the photos of your boat that you've raised the transom quite a bit, so a 25" shaft is probably just right.  As light and efficient as these hulls are, I'd think a 3-blade would probably be your best choice.
February 18, 2015, 10:06:47 AM
« Reply #2 on: February 18, 2015, 10:06:47 AM »
A 14-1/2 x 17 should get you close, I believe that is what capt matt is running on his flatback with a 150 4stroke...
