Family Fisherman/Dual Console/Sport Rider Rebuilds
Painting 1986 222 Dual Console Sandpiper
Topic: Painting 1986 222 Dual Console Sandpiper (Read 2720 times)
February 08, 2015, 01:59:19 PM
Read 2720 times
Aaron43
February 08, 2015, 01:59:19 PM »
1st coat of paint...shows every flaw in the hull....long way to go.
February 08, 2015, 02:01:16 PM
Aaron43
Re: Painting
February 08, 2015, 02:01:16 PM »
February 08, 2015, 02:02:38 PM
Aaron43
Re: Painting
February 08, 2015, 02:02:38 PM »
February 08, 2015, 02:57:10 PM
Re: Painting
February 08, 2015, 02:57:10 PM »
Looks good though
February 08, 2015, 03:24:14 PM
Aaron43
Re: Painting
February 08, 2015, 03:24:14 PM »
Thanks Rick....seems like a lot of sanding and little reward....
February 08, 2015, 03:34:26 PM
Re: Painting
February 08, 2015, 03:34:26 PM »
So, you're going to have to spill the beans on the process and what kind of paint - the membership won't let you off that easy
February 08, 2015, 03:42:43 PM
Aaron43
Re: Painting
February 08, 2015, 03:42:43 PM »
Interlux Brightside paint, poly....sanded the the hull, filled all of the dings and cracks, sanded the hull again, fared it, wiped it down with the product Interlux recommended, 333 I think? sprayed on a coat of paint, now its recommended a 320 grit sanding, and repaint. Think Im going to have to fair it a lot more but my money and patience is running out so we will see.
The bottom paint is Marpac paint, a hard ablative paint.
February 08, 2015, 05:51:39 PM
Re: Painting
February 08, 2015, 05:51:39 PM »
So the brightside is poly based or for poly? Is it two part?
February 08, 2015, 08:17:32 PM
Aaron43
Re: Painting
February 08, 2015, 08:17:32 PM »
http://www.jamestowndistributors.com/userportal/product.do?part=3691&engine=adwords!6456&keyword=product_ad&gclid=CLSs7qrY08MCFU0vgQod0ZQATw
Interlux Brightside Polyurethane is the most technically advanced one-part polyurethane available. It contains unique additives that make cleaning easier and help reduce stains and abrasion.
Brightside uses Polyflow 4000, a unique polyurethane resin, which yields excellent flow and leveling characteristics as well as incredible abrasion and chemical resistance. Brightside also takes advantage of the latest in ultraviolet technology which insures longer color and gloss retention.
Together these technologies create a one-part polyurethane which gives the look of a two-part polyurethane with the application ease of a one-part enamel.
February 08, 2015, 08:21:19 PM
Re: Painting
Reply #9 on:
February 08, 2015, 08:21:19 PM »
Hmmm, wonder if it can be roll and tipped with good success?
February 08, 2015, 08:30:07 PM
Aaron43
Re: Painting
Reply #10 on:
February 08, 2015, 08:30:07 PM »
I bought it specifically on the recommendation of a friend who uses it as a roll and tip paint. Then my painter friend wanted to spray it on...looks ok so far but i think rolling and tipping for the 1st coat would have been thicker and covered better.
February 10, 2015, 06:34:34 PM
Aaron43
Re: Painting
Reply #11 on:
February 10, 2015, 06:34:34 PM »
The 2nd coat went on yesterday.....covered a lot better this time.
February 10, 2015, 06:35:15 PM
Aaron43
Re: Painting
Reply #12 on:
February 10, 2015, 06:35:15 PM »
February 10, 2015, 06:36:05 PM
Aaron43
Re: Painting
Reply #13 on:
February 10, 2015, 06:36:05 PM »
February 10, 2015, 06:36:59 PM
Aaron43
Re: Painting
Reply #14 on:
February 10, 2015, 06:36:59 PM »
