Author Topic: 1971 22-2 Flatback Refurb  (Read 2871 times)
February 05, 2015, 06:46:38 PM
Re: 1971 22-2 Flatback Refurb
« Reply #15 on: February 05, 2015, 06:46:38 PM »
 :whistle:
Really nice
February 06, 2015, 07:46:12 AM
Jack Hart
« Reply #16 on: February 06, 2015, 07:46:12 AM »
I put down the deck non-skid by rolling on a layer of paint, then using a large salt shaker to sprinkle on non-skid material evenly.  After the paint dried I rolled on another coat.  It came out pretty nice.  I've tried mixing non-skid in the paint, but it always came out very patchy.  I now recommend the salt shaker method.
February 06, 2015, 08:09:50 AM
« Reply #17 on: February 06, 2015, 08:09:50 AM »
Same method I use but with gelcoat instead of paint.
February 07, 2015, 09:19:01 AM
Jack Hart
« Reply #18 on: February 07, 2015, 09:19:01 AM »
With much crawling around on my belly and some grunting and groaning, I got the boat back on the trailer.  Two bottle jacks and the borrowed stands made it a one man job.
Then engine and jack plate were reinstalled next in order to get some of the tongue weight off the trailer.
Then the fuel tank:
and finally the console:
February 07, 2015, 09:34:24 AM
« Reply #19 on: February 07, 2015, 09:34:24 AM »
Looks like it's coming along nicely. I also did the salt shaker method but with gelcoat
February 07, 2015, 09:53:18 AM
« Reply #20 on: February 07, 2015, 09:53:18 AM »
I guess I don't quite understand the area under the console  :?:  Maybe it's the way the picture is.
Is that an added layer for under the fuel tank?
February 07, 2015, 11:53:57 AM
Jack Hart
« Reply #21 on: February 07, 2015, 11:53:57 AM »
What you're seeing is the lid to the well sitting on top of the area where the console will sit.  I didn't see any need to non-skid the area under the console, and I was running short of paint and non-skid.
February 07, 2015, 01:48:23 PM
« Reply #22 on: February 07, 2015, 01:48:23 PM »
ahHAA - I see it now - makes perfect sense.  Thanks for clearing that up for me. :salut:
February 08, 2015, 08:23:46 AM
Jack Hart
« Reply #23 on: February 08, 2015, 08:23:46 AM »
I bought 250' of tinned marine wire in appropriate colors and used it all.  Here are a few shots of the rigging chaos.
February 09, 2015, 07:23:02 AM
Jack Hart
« Reply #24 on: February 09, 2015, 07:23:02 AM »
All the gauges and switches hooked up and working.  Gauges include tach, water pressure, fuel level (I can still dip the tank), and simple depth.  I don't find much use for a fishfinder in the shallow water where I fish.  The gps chartplotter is way more useful.  A hint for anyone installing control cables on older Evinrude/Johnsons:  the bracket that locks the cable to the motor can be mounted two ways.  If you mount it with the tab up, you won't be able to get into reverse.  I found out the hard way and it took a lot of head scratching to figure it out.
Here's a view of the new rub rail and the funky bow fitting that I elected to keep.  I did replace the bulb with an LED.  Rub rail is expensive and white is hard to find, but I went to Boat Builder Central and found a great deal on rub rail that fit perfectly and looks really good.
February 09, 2015, 07:33:10 AM
« Reply #25 on: February 09, 2015, 07:33:10 AM »
looks good! wont be long before she's in the water!
February 09, 2015, 08:08:32 AM
« Reply #26 on: February 09, 2015, 08:08:32 AM »
 :thumright:
February 10, 2015, 07:57:56 AM
Jack Hart
« Reply #27 on: February 10, 2015, 07:57:56 AM »
Waiting for a windshield and grab bars.  Hopefully they'll come this week.  I hauled the boat out and fueled up.  Gas at $2.10 a gallon!  When I started in October it was more like $3.75.
The trolling motor batteries and charger are behind the Ipe hatch covers.  All the original wood was stripped and repainted, but I had to make the hatch covers.
A rotomolded ice chest this size costs about $500. I pulled this vintage chest out of my trash pile (free) and with a little Clorox and elbow grease it's perfect, and also of 1971 vintage.
February 10, 2015, 08:27:01 AM
« Reply #28 on: February 10, 2015, 08:27:01 AM »
 :thumleft:  Excellent work, the boat looks great!  Look forward to seeing photos from the maiden voyage.
Don't forget your shoes in the summer time, I think that color you put down on the deck is going to get hot.
February 11, 2015, 07:40:54 AM
Jack Hart
« Reply #29 on: February 11, 2015, 07:40:54 AM »
I found some LED strip lights on E-bay, 18 feet for $10 delivered.  They came directly from China and I was skeptical but figured that for the price I couldn't go too far wrong.  It took about 10 days for them to be delivered, but they worked great.  They're waterproof with an adhesive backing and can be dimmed with a rheostat.
Here's what they look like mounted under the gunnels and at full brightness:
