Author Topic: 1977 22 -2 rebuild  (Read 6268 times)
October 09, 2015, 09:49:14 PM
Reply #60
Que Pasa
  • NorthEast
Re: 1977 22 -2 rebuild
« Reply #60 on: October 09, 2015, 09:49:14 PM »
No wood for me, I'll use some type of composite.
October 10, 2015, 11:20:53 AM
Reply #61
Que Pasa
  • NorthEast
« Reply #61 on: October 10, 2015, 11:20:53 AM »
I measured and if I lay my floor 3/4 " above my original floor it leaves a 2" inch gap between the stringer top and bottom of the floor. :confused1:
October 10, 2015, 02:15:35 PM
Reply #62
« Reply #62 on: October 10, 2015, 02:15:35 PM »
I'd say you had a lot of bonding putty on the top of the stringers :c029:
October 10, 2015, 09:31:42 PM
Reply #63
Que Pasa
  • NorthEast
« Reply #63 on: October 10, 2015, 09:31:42 PM »
It was over a half inch in spots.
October 13, 2015, 11:42:05 AM
Reply #64
northfork
« Reply #64 on: October 13, 2015, 11:42:05 AM »
When I removed my old deck I had some areas that had 1/2" of bonding putty on top of the stringers. That stuff was crazy hard to remove.
October 13, 2015, 05:47:49 PM
Reply #65
Que Pasa
  • NorthEast
« Reply #65 on: October 13, 2015, 05:47:49 PM »
Yeah I went through about 3 grinding disc's. Have you measured how far your finished floor will be from the stringer tops. Mine is over 2 inches in spots!
October 14, 2015, 11:10:51 AM
Reply #66
northfork
« Reply #66 on: October 14, 2015, 11:10:51 AM »
I have around 2" in some spots. I'm raising the top of the stringers to make up the difference and to reduce the amount of bonding material.
October 15, 2015, 08:47:42 AM
Reply #67
Que Pasa
  • NorthEast
« Reply #67 on: October 15, 2015, 08:47:42 AM »
North, have you figured out your cradle for your gas tank yet? And will you be adding extra glass out board of your stringers. Just trying to get a feel of what others are doing. I keep going back and forth in my head of whether to mold the bulkheads like the stringers or just use coosa and glass it in.
October 15, 2015, 11:10:51 AM
Reply #68
northfork
« Reply #68 on: October 15, 2015, 11:10:51 AM »
Que
I added 3 layers of 1708 across the entire inner hull and up the side of the existing stringers. I went up the hull sides as far as I could. I cut my bulkheads out of 1 1/2 Coosa. I have them all cut and shaped
but not glassed in yet. I'm doing bulkheads at 4' on center to pick up seams of floor deck. I did not start my tank coffin yet. I have a plan but I am going one step at a time. That's next after the bulkheads.
October 15, 2015, 03:50:45 PM
Reply #69
Que Pasa
  • NorthEast
« Reply #69 on: October 15, 2015, 03:50:45 PM »
Wow 3 layers, you're a gluten for punishment. I think two for me down the center and one outboard of the stringers, it feels like i'm building a battleship.
October 15, 2015, 04:05:54 PM
Reply #70
« Reply #70 on: October 15, 2015, 04:05:54 PM »
Battleships are a good thing  :08:
November 03, 2015, 08:50:13 AM
Reply #71
Que Pasa
  • NorthEast
« Reply #71 on: November 03, 2015, 08:50:13 AM »
North being that you left the original stringers in, have you given any thought to the centering of your fuel tank? I know my stringers are not centered in the boat, I'm concerned with my placement. I would hate to have done all this work and have the boat lean one way or another.  :a102:
November 03, 2015, 10:32:56 AM
Reply #72
northfork
« Reply #72 on: November 03, 2015, 10:32:56 AM »
My stringers are as close to centered as you could get. How much are yours off by.
I haven't been doing much on my boat lately.
Went out for opening day of scallop season yesterday and saw 2 old aquasport 22-2 converted into work boats.
We had a great day. Temps in mid 50's and light wind. 20 bushels by 12:30
November 03, 2015, 02:36:24 PM
Reply #73
« Reply #73 on: November 03, 2015, 02:36:24 PM »
Sounds tasty.  I had some scallops at a restaurant Saturday and these things were 2" across and 1.5" tall  ::o:
Didn't know scallops came that big.
November 05, 2015, 04:18:46 PM
Reply #74
Que Pasa
  • NorthEast
« Reply #74 on: November 05, 2015, 04:18:46 PM »
You have that measurement for me.
