Paints, topsides and bottom and Gelcoat Topics
paint removal
Topic: paint removal (Read 726 times)
January 23, 2015, 08:58:53 PM
Read 726 times
Aaron43
paint removal
January 23, 2015, 08:58:53 PM »
My 22 has what looks like house paint on the deck, I m thinking latex? I want to chemically strip it off....Anyone have a product recommendation that will not eat away the fiberglass?
January 23, 2015, 09:40:53 PM
Global Moderator
Re: paint removal
January 23, 2015, 09:40:53 PM »
Latex paint will soften when rubbed with alcohol (rubbing not drinking).
Try a spot first to determine if it is latex. If so, painting the surface with iso and covering with plastic ( so it doesn't evaporate) will soften the paint. I've done this on wood doors before.
Since it's on the deck, a pressure washer should make it easier to remove once it has soaked and become soft.
January 23, 2015, 10:05:00 PM
Aaron43
Re: paint removal
January 23, 2015, 10:05:00 PM »
Thx...Ill try the alcohol tomorrow....
January 23, 2015, 10:44:41 PM
Re: paint removal
January 23, 2015, 10:44:41 PM »
If Bob's approach doesn't work...I used this stuff on part of my bottom paint:
I painted it on, covered it with a sheet of plastic, let it sit for a couple hours, and then took a paint scraper to it. Here is what I was left with:
As you can see it helped, but it was not completely effective. I may have been able to apply another coat and get more off, but from there I used a sander and 40 grit paper, which is what I used on the rest of the boat.
I'm not sure how it would do with whatever paint you have, but if you try it, I would use a test spot like Bob suggested.
January 24, 2015, 08:07:17 AM
Aaron43
Re: paint removal
January 24, 2015, 08:07:17 AM »
Where did u buy that stuff Rick?
January 24, 2015, 09:06:44 AM
Global Moderator
Re: paint removal
January 24, 2015, 09:06:44 AM »
Quote from: Aaron43 on January 24, 2015, 08:07:17 AM
Oh Oh Oh O'Rielly Auto parts here in Tallahassee carries it. I've used their (Klean Strip) product on metal parts before with good results. Might find it at a HD , Lowes or Ace.
January 24, 2015, 09:32:30 AM
Re: paint removal
January 24, 2015, 09:32:30 AM »
I assume you are asking about the stuff I used (but I'm not Rick). I bought it online (couldn't find it locally), but I don't remember where. I think I bought it almost 2 years ago (yes, I've been working on my rebuild that long). It's not cheap....
January 24, 2015, 10:09:55 AM
Global Moderator
Re: paint removal
January 24, 2015, 10:09:55 AM »
This is a guess based on your area.
http://www.oreillyauto.com/site/c/detail/KLN3/AF3541/N0483.oap?ck=Search_N0483_-1_4803&pt=N0483&ppt=C0171
Not in stock but you might check how long to get.
January 24, 2015, 10:32:06 AM
Re: paint removal
January 24, 2015, 10:32:06 AM »
We didn't have an o'Reillys nearby when I bought mine, but the price showing on the website is much better than I paid!
January 25, 2015, 10:18:51 AM
Aaron43
Re: paint removal
Reply #9 on:
January 25, 2015, 10:18:51 AM »
Sorry CLM65, it was u I was asking....I got some and it worked well, only thing is now that the paint is off I have found some sort of 2 part epoxy type paint/non skid.....Im looking at just sanding what I have and putting new non skid over the entire deck....I tried removing the old stuff only to find myself digging into the old gelcoat and making it worse...I called a fiberglass guy we deal with at work and he said get some boat turf as he laughed at my situation....ughhh
Progress on rebuild:
http://classicaquasport.com/smf/index.php?topic=12784.msg129394#msg129394
paint removal
