Ditto what Bob said, fixing a pitted aluminum tank is not worth the risk... Replace it. As far as drainage goes, I'll give you an example. My tank on my '73 22-2 was replaced in '94. This weekend, I pulled the hatch to replace the fuel lines that have been there since the tank was replaced. The hatch was sealed very well with silicone sealer. When I pulled the hatch the fuel tank is still like the day it was installed, the hatch still like new with zero rot, the foam surrounding it, bone dry. Even the fuel line still looked new, but 20 years is way too long on a fuel line so I had to go in. The point is if the hatch is sealed correctly, the tank will last indefinitely.
