Author Topic: Old Merc 150 pisser question  (Read 2952 times)
January 08, 2015, 12:44:46 PM
Re: Old Merc 150 pisser question
« Reply #15 on: January 08, 2015, 12:44:46 PM »
IMO a water pressure gauge > temp gauge
X10.
January 08, 2015, 12:50:55 PM
Fletch170
« Reply #16 on: January 08, 2015, 12:50:55 PM »
Cool, Novice question.
Is there a factory sender on my motor that senses water pressure, what would relay water pressure to said gauge?
1981 2100 CC Hydra Sport
1976 170 (sold)
January 08, 2015, 01:06:35 PM
Georgie
« Reply #17 on: January 08, 2015, 01:06:35 PM »
IMO a water pressure gauge > temp gauge. At Idle you should get 3 - 4 Ibs of pressure, if you have that the water pump is suppling water to the block.
Please forgive my merc ignorance, but I don't think the pressure gauge could ever tell you if your Tstats/poppets were clogged or failing to open.  You'd be running hot with a ton of water pressure b/c the impeller is working, but nothing is passing through the engine and out the exhaust, and you'd be none the wiser when in the water, right?  :017:
If it's anything like OMC, you'd just run a hose from a T-connector spliced into your pisser forward through your wiring trough and connecting it to the back of the pressure gauge.
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
January 08, 2015, 01:25:38 PM
« Reply #18 on: January 08, 2015, 01:25:38 PM »
Well, we have been down this road before and both gauges have their respective base (like trim tab types).
While I don't currently have a dedicated water/head temp gauge on my Yamaha, I have toyed with the thought for one since I got it in 2009. I agree that a water pressure gauge cannot tell if the t-stats are functioning correctly and it tells nothing of the operating temps at speed. Still, as stated it can indicate water pump servicing at idle but to my way of thinking, not a lot more than the visible telltale does. With modern gauges/alarms/motor controls, the water/pressure gauge is more like a belt with suspenders and since regular service/replacement of these parts (impeller/tstats/poppet valve) is highly indorsed by Forum members here, the question is ,"are they still required or have they gone the way of points/condenser ignition"?
January 08, 2015, 02:07:26 PM
« Reply #19 on: January 08, 2015, 02:07:26 PM »
Keep in mind CB, Yamahas, the port for the WP fitting is on top of each head...the water feeding your gauge has to pass through the entire head cooling jacket before it hits that fitting.  So it's not like you're just seeing WP off the water pump.  Same with Mercs.  On OMC V6s, the fitting is installed at the base of the starboard head, but I would assume the principle is the same.
It would be of no use if engine manufacturers designed the motor such that the WP fitting was upstream of the head cooling passages, as that would give absolutely 0 info as to the health of the water stream through the motor...
January 08, 2015, 02:22:38 PM
Fletch170
« Reply #20 on: January 08, 2015, 02:22:38 PM »
Bob, I'm going to go see if my motor has anything like that at the top of the head.....I dont think it does, but then agian I'm wrong.........alot.
1976 170 (sold)
January 08, 2015, 02:57:43 PM
« Reply #21 on: January 08, 2015, 02:57:43 PM »
OK, while I am aware of that, it isn't the point I'm trying to make. While each gauge has merits, the pressure seems a less useful tool to my way of thinking. At high speed operation, it shows water flow but not temperature change. Same at low speed operation. If you have a cylinder running lean and causing an elevated temperature it can't indicate that.
Both sides can make a point for their gauge but at the end of the day several more things can cause overheating besides poor water pressure and none of those can be detected by the pressure gauge. Lastly, because some tend to enjoy the state of boating rather than being focused on actual operation, no matter what gauge one chooses, it only works if you tend to look at it from time to time. Modern engines move that responsibility to the manufacturer and it's probably in the the best interest for all concerned. Pay more attention to where you're heading and less to the function.
Ok then, why do I still consider a temperature gauge? I'm old in my ways and it was an important indicator on engine condition before all the fancy computer/sensors/save your butt systems we have today (remember my outboard was built in 1991 but has these things). I also have a GPS that I like a lot but still use my compass every time I'm out. Old habits are very hard to break.
January 08, 2015, 03:23:57 PM
Fletch170
« Reply #22 on: January 08, 2015, 03:23:57 PM »
Just read through my Shop manual, the Offshore carb does not have any water pressure sensor. Bummer.
The only reson I'd like that is here in Jersey, we have a big tide swing, and some really muddy bottoms.
1976 170 (sold)
January 08, 2015, 03:48:00 PM
« Reply #23 on: January 08, 2015, 03:48:00 PM »
January 08, 2015, 03:49:01 PM
« Reply #24 on: January 08, 2015, 03:49:01 PM »
There are no "sensors" for WP.  You have to install a fitting that feeds a pitot tube running forward to the WP gauge...
January 08, 2015, 09:11:27 PM
« Reply #25 on: January 08, 2015, 09:11:27 PM »
This sure has become an interesting thread.  Like debating Chevy vs Ford,  Blondes vs brunettes.  :06:
This is why outboards come with an overheat alarm.
January 09, 2015, 10:49:14 AM
« Reply #26 on: January 09, 2015, 10:49:14 AM »
The telltale (pisser) should have water coming out all the time.  The line for the telltale comes off the cooling lines before the thermostats.  A water pressure gauges connects to a port that is on the water jacket for one head.  Some folks find the water pressure gauge is more effective than a temperature gauge because it will tell you of a problem with water pressure BEFORE it impacts engine temperature.  By the time you see a high engine temp, the problem is likely too far gone and you are not likely to fix it on the water.  Mercs will run at "normal" temperatures with only 5 PSI or less of water pressure.  A water pressure gauge helps you better see the condition of the system - if it normally is running 10-15 PSI at speed and you notice water pressure is down to 5-6 - you know you probably need to change an impeller, clear a clog , or check the water pickup.
January 09, 2015, 12:26:15 PM
Aquamaniac
« Reply #27 on: January 09, 2015, 12:26:15 PM »
Actually, as OP,  this thread has been interesting and helpful to follow.
Particularly if you are trying to learn your way sorting out an old motor!
For example:
   here is a pic of a fitting I was wondering about.....look familiar?
The hard plastic line is just bent and closed off. Very professional....go figure...... ::)
Anyway, thought I would point out that while a thread might get hum-ho to folks very knowledgeable in the subject, there are those of us still crawling up the learning curve and discussion is a great source of info.
Thanks!
January 09, 2015, 12:34:04 PM
« Reply #28 on: January 09, 2015, 12:34:04 PM »
At least that hard plastic line didn't crack where the PO bent it.  Would've had salt water spraying all over that powerhead...
January 09, 2015, 01:00:26 PM
« Reply #29 on: January 09, 2015, 01:00:26 PM »
OK then,
If the tell tale should be pissin' at start, you may just have a blockage at the exit. Might want to try a thin wire inserted into the nozzle and see if it clears the line.
My Yamaha is set up that way with the WP line on the left bank and the temp on the right, similar to your photo.
