Author Topic: 1970 flat back rebuild  (Read 2221 times)
January 03, 2015, 09:04:27 AM
Read 2221 times
watwood
« on: January 03, 2015, 09:04:27 AM »
So I have been on this site for a few years reading all of your impressive rebuilds and I am finally ready to get to work on my flattie. The goal is to close in the transom and now that I have the deck stripped it's painfully obvious that the deck needs to be reaced. As this will be my first attempt at this type of resto I am hesitant but will most likely be on here asking a lot of questions. The first (of many to come) is how far off the funnel should I cut the deck for removal as I know I want to leave a lip there? Also the best way to remove the casting deck. Thank you all for any advice you can give as I'm sure I will need all the help I can get.
       -Bill
January 03, 2015, 09:20:41 AM
Re: 1970 flat back rebuild
« Reply #1 on: January 03, 2015, 09:20:41 AM »
Howdy Bill, IMO 1 1/2 - 2 inches should do the trick.  Good luck and post photos.  :icon_salut:
January 03, 2015, 11:35:15 AM
« Reply #2 on: January 03, 2015, 11:35:15 AM »
Ditto on what Nando said.  A sawzall with a long agressive blade can be a good tool for the casting deck removal.  Just make sure you know where the blade is at all times :icon_thumleft:
January 05, 2015, 03:29:41 PM
watwood
« Reply #3 on: January 05, 2015, 03:29:41 PM »
So I pulled the condone and everything off the deck and just as I suspected the deck itself squeezed out water. I have pics on my profile but am still trying to post on this thread. Within the next few days I will be cutting the deck and fishing platform. What is the best tool to open up the transom? I'm excited and scared to death about all this work I'm making for myself but it's clear if had to be done haha
http://www.classicaquasport.com/gallery/showgallery.php?cat=500&ppuser=64736
January 05, 2015, 05:56:02 PM
« Reply #4 on: January 05, 2015, 05:56:02 PM »
How are you going to do the transom?  Poured or composite/wood.  If you do the poured you'll want to save the inside side skin.  If you are replacing the transom with composite or wood a skill saw is good to score it deep and then an air chisel is great to peel it out.
January 05, 2015, 06:38:18 PM
« Reply #5 on: January 05, 2015, 06:38:18 PM »
If not pouring and are going with composite or wood be sure and leave the outside skin as there is a lot of strength in the corners.
January 15, 2015, 09:12:43 AM
watwood
« Reply #6 on: January 15, 2015, 09:12:43 AM »
January 15, 2015, 09:27:33 AM
« Reply #7 on: January 15, 2015, 09:27:33 AM »
You're gettin' the hang of it.
Post up some more showing the progression. Moving from the Gallery to here is easy enough.
Good luck! :13:
January 15, 2015, 09:35:30 AM
watwood
« Reply #8 on: January 15, 2015, 09:35:30 AM »
Before the first cuts
And this is what I found
January 15, 2015, 09:43:53 AM
watwood
« Reply #9 on: January 15, 2015, 09:43:53 AM »
January 15, 2015, 09:48:48 AM
watwood
« Reply #10 on: January 15, 2015, 09:48:48 AM »
So it's safe to say this needed to be done
January 15, 2015, 12:01:28 PM
« Reply #11 on: January 15, 2015, 12:01:28 PM »
Hi,
That boat has been into before. Take out the rest and lets see what you have :13:
January 15, 2015, 06:43:01 PM
« Reply #12 on: January 15, 2015, 06:43:01 PM »
Ditto on what Gran said
I guess they built it up to support the forward storage box that you took out - one way to do it I guess.
January 15, 2015, 08:30:13 PM
« Reply #13 on: January 15, 2015, 08:30:13 PM »
Here is what the original FB stringer system looked like
January 16, 2015, 01:28:50 PM
watwood
« Reply #14 on: January 16, 2015, 01:28:50 PM »
And there goes the deck
