Author Topic: Well, this is different...  (Read 2598 times)
January 02, 2015, 12:51:20 PM
Re: Well, this is different...
« Reply #15 on: January 02, 2015, 12:51:20 PM »
I have the developers looking at the gallery and Avish is tweaking some stuff so let's back out of the gallery for a bit to see what they can come up with. (SB this might explain why you're getting the errors)
January 02, 2015, 01:02:38 PM
« Reply #16 on: January 02, 2015, 01:02:38 PM »
 :o
 8)   :-*
 :D
January 02, 2015, 01:21:34 PM
Avish
  • Developer - IT Team
« Reply #17 on: January 02, 2015, 01:21:34 PM »
Gallery should be fully working now.
Avish J.
Classic Aquasport | IT Admin
Evolucix | CEO
http://www.evolucix.com
January 02, 2015, 01:24:14 PM
« Reply #18 on: January 02, 2015, 01:24:14 PM »
Thanks Avish !!
January 02, 2015, 01:24:30 PM
« Reply #19 on: January 02, 2015, 01:24:30 PM »
Indeed :)
January 02, 2015, 01:34:54 PM
« Reply #20 on: January 02, 2015, 01:34:54 PM »
Cute little fella - relative of yours CB?  :P
We still have some item in the gallery not working correctly but it should not affect you guys.
January 02, 2015, 01:39:23 PM
« Reply #21 on: January 02, 2015, 01:39:23 PM »
Sent with my Droid.
OK,
No that's not my uncle Fred. Eddie is much more attractive.
I was able to rotate Eddie's pic and then post. Also, I copied another of Dburr's pics and posted with my phone. Seems to be working better now. I'll try an iphone later after my son gets off work.
January 02, 2015, 01:46:13 PM
dburr
« Reply #22 on: January 02, 2015, 01:46:13 PM »
Sent with my Droid.
OK,
That was braised short ribs and asparagus Rissoto... Now I am hungry. Will try loading Eddie again..
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
January 02, 2015, 01:54:30 PM
« Reply #23 on: January 02, 2015, 01:54:30 PM »
Dave,
I rotated Eddie in your gallery. He should be upright. I noticed another pic that needs rotating. You can do that via "edit".
Also I noticed that since we changed smileys, all the older posts lost theirs but then you guys probably knew that already.
January 02, 2015, 02:08:06 PM
dburr
« Reply #24 on: January 02, 2015, 02:08:06 PM »
Must be me...
From the profile page.
1st try was Upload Avatar.  This takes me right to the photo gallery on the pad.. Select the picture, then it loads and I can see a tiny picture.  Then hit change profile and nothing happens..
Then try specify by URL, I try Eddies URL and Thumbnail.. Nothing but the little blue ?
So, I assume it is me..
Thoughts?
And Thanks CB for spinning the little dude around!
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
January 02, 2015, 02:56:30 PM
« Reply #25 on: January 02, 2015, 02:56:30 PM »
OK Dave,
This is what I did from my laptop, not my phone.
Went to your Gallery, right clicked on Eddie and from the drop down box clicked on "copy image location".
Next I went to your profile and made sure I clicked on the "Specify avatar by URL".
Made sure box was blank.
Clicked on box and pasted (Ctrl+v).
This pasted the link of Eddie I copied into the box (that was completely blank).
Clicked "change profile" lower right and he appears as your avatar.
Note: I did not size the avatar first. I used the size of Eddie's pic from the Gallery as posted and the Forum software resized the avatar.
Haven't tried this from my phone but will later.
January 02, 2015, 03:52:32 PM
dburr
« Reply #26 on: January 02, 2015, 03:52:32 PM »
Many thanks CB!
I do 99% of my viewing on the iPad.  You did the same thing I did but you won!  My conclusion is that it is possibly an iPad issue.
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
January 02, 2015, 04:41:25 PM
« Reply #27 on: January 02, 2015, 04:41:25 PM »
From my iPhone I can't seem to do much with pics except upload them .  Seems the mobile portion is too dumbed down.  From my droid tablet I can't do any more than that either. I will look into it some more once the site settles in a bit, so I don't break it on the first day  ??? .
January 02, 2015, 06:53:56 PM
« Reply #28 on: January 02, 2015, 06:53:56 PM »
Well I guess I should jump in here since CB can't do any of the items you mention.
1) I'll look into the join date.  I know that I cannot tell you your member number anymore because SMF assigns a random number that means nothing.
2) Let me look at the sig box - should accept the normal BBC code like before
3) I have a few smilie packages that I installed, I'll see if I can use the old one too - so a WIP.
4) Not sure but I'll look into it.
Thanks for the feedback
#1 Done - is under your Avatar so you can remove or change your personal message.  I can config it to show location or join date or both.
#2 We know you can use BBC codes http://http://www.bbcode.org/reference.php
#3 Working on it
#4 Done
January 02, 2015, 08:19:06 PM
« Reply #29 on: January 02, 2015, 08:19:06 PM »
#3 - Done plus I added a few into the pack - can add them all if we want.
