200 Rebuilds
rebuild question
Topic: rebuild question (Read 5854 times)
February 22, 2005, 10:29:02 AM
Read 5854 times
scott_gunn
rebuild question
February 22, 2005, 10:29:02 AM »
My boat is an 87 Osprey 200 (19'6"). The deck seems fine (there are some spider cracks) and my boat is floating plenty high. Should I be worried about redoing the stringers and deck? I'd rather just redo my console and install a leaning post before I move on to the cool stuff (jack plate & trolling motor).
How easy is it to check for water intrusion, and how is it done? Should I even be worried about it?
Thanks,
Scott
February 22, 2005, 10:40:00 AM
Seadog
February 22, 2005, 10:40:00 AM »
Hey Scott. Welcome to the forum!
I wouldn't worry too much about spider cracks in the floor gel-coat. That's probably from the flex in the floor since 1987.
The only way to check the integrity of the deck and stringers is to cut it open and look. Doesn't sound like that's too much of a concern if the floor feels solid.
The leaning post might need some backing under the floor to secure it down tight. As opposed to just screwin it down thru the glass.
Keep us posted.
1970 Aquasport 222
Spring Hill, Fl.
February 22, 2005, 10:49:48 AM
Wilson
February 22, 2005, 10:49:48 AM »
Have you drilled into the transom to install anything? You can check the wood that comes out to see if you have wet wood. Othewise, Seadog is right you have to start cutting to see.
Are you noticing flex in the transom? You can tilt the engine all the way up and stand on the motor and bounce a little. You will be able to see if there is flex and therefore wet, bad, delaminated transom.
Wilson Ayala
Tampa, FL
February 22, 2005, 10:54:05 AM
scott_gunn
February 22, 2005, 10:54:05 AM »
Thanks for the replies. The transom is fine - it was rebuilt a few years ago, right before I bought the boat.
February 22, 2005, 11:32:49 AM
Wilson
February 22, 2005, 11:32:49 AM »
That's great. If there are no soft/squishy spots on the deck, then don't worry about it. The test is simply walking all over the thing and checking. You probably would have noticed.
Wilson Ayala
Tampa, FL
February 22, 2005, 12:39:38 PM
scott_gunn
February 22, 2005, 12:39:38 PM »
The only place where I notice any squishiness is directly over the bilge access - but I've always assumed it was normal because that's the largest area unsupported by stringers. If it's deflecting at all (even just a little) does that mean maybe some plywood in my deck is wet and rotting?
February 22, 2005, 12:55:51 PM
Argo
February 22, 2005, 12:55:51 PM »
My fuel cover was softt and I have a soft spot around the anchor box hole up front which I will be cutting out and making into a bigger access hole anyhow. Every other part of my deck is rock solid which suprised me on an 81.
February 22, 2005, 01:28:22 PM
Seadog
February 22, 2005, 01:28:22 PM »
Quote
Scott - do you mean the bilge access hatch itself or around the rim?
1970 Aquasport 222
Spring Hill, Fl.
February 22, 2005, 01:32:49 PM
scott_gunn
February 22, 2005, 01:32:49 PM »
Not the actual hatch itself - that whole section of the floor will give just a tiny bit when I stand in the middle of that section.
February 22, 2005, 01:51:39 PM
Seadog
February 22, 2005, 01:51:39 PM »
Is there enough room inside the bilge access to take a look around and see how far back the stringers go. Is the floor flexing part on or near a stringer? I guess you probably know where this is leading.
Not sure how your 200 Osprey stringers are laid out, but it might have a central stringer, running down the middle of the hull that will stop a foot or more forward of the transom. That part of the floor will be unsupported by the stringers and may not be a big deal.
But if the floor flex is on or near a stringer then you may have some troubles ahead.
1970 Aquasport 222
Spring Hill, Fl.
February 22, 2005, 01:58:03 PM
scott_gunn
February 22, 2005, 01:58:03 PM »
It's not near any stringers - it's just the floor flexing, not the stringers.
There is no central stringer - if there is it stops well short of the bilge access near the transom.
Thanks for your help!
February 23, 2005, 10:16:52 PM
GradySailfish25
February 23, 2005, 10:16:52 PM »
Scott,
I have the same boat as you, just picked it up. The deck is solid but it isn't level. It seems to have some crown to it, mostly from the console back. Ever seen this?
February 24, 2005, 12:38:46 PM
scott_gunn
February 24, 2005, 12:38:46 PM »
I've never noticed a crown. I'll try and remember to check when I get home.
February 26, 2005, 10:48:33 AM
scott_gunn
February 26, 2005, 10:48:33 AM »
Yes, it does slope down around the edges, but is not noticeably crowned in the center.
February 26, 2005, 12:10:58 PM
Wilson
February 26, 2005, 12:10:58 PM »
It should have a slight camber, so that the water flows to the sides then out of the boat.
Wilson Ayala
Tampa, FL
200 Rebuilds
rebuild question
