Author Topic: 1999 yamaha 250 ox66 fuel pump don't prime  (Read 484 times)
December 27, 2014, 07:58:37 PM
Read 484 times
Earl
« on: December 27, 2014, 07:58:37 PM »
Hello I  am  newbie to these outboards I bought them a couple months ago from a guy In the Tampa Bay Motors have good compression But the starboard engine doesn't start spray gas into the throttle bodies The motor fires up but does not keep running also when I turn the key switch I don't hear the fuel pump cycle the fuel pump does have power to it . I also tried jumping the fuel pump the fuel pump does work but the engine still doesn't run anyone know what controls the electric fuel pump or does it go through the harness  any help would be much appreciated. I even tried switching the computer And switching the main wire harness and nothing changed.
December 28, 2014, 12:19:40 PM
futch13
Re: 1999 yamaha 250 ox66 fuel pump don't prime
« Reply #1 on: December 28, 2014, 12:19:40 PM »
Fuel pump is triggered by ground.  B+ is always there with key on.  Pump is probably bad.
January 09, 2015, 08:27:35 AM
jdupree
« Reply #2 on: January 09, 2015, 08:27:35 AM »
Double check your LP pumps.   I had the same situation and I thought the HP pump was bad but turned out to be the LP pumps.  Sounds like you do have an issue with the HP pump wiring if you can jump it and it works.  If it still won't stay running check your LP pumps.
Just unbolt the LP pumps from the powerhead and pump your fuel bulb with your hand on the back of the LP pump.  If you feel gas LP pump is most likely bad.  Typically, you won't get much more than one season out of the LP pumps.
John L. Dupree, III
AQABLA84E999
Member #257
