Author Topic: Aquasport 281 ff  (Read 3217 times)
December 11, 2014, 07:01:51 PM
Read 3217 times
aqua
Aquasport 281 ff
« on: December 11, 2014, 07:01:51 PM »
hello , i 'm  search for the 1987 - 1988 brochure on the aquasport 281 ff . Thank's
December 12, 2014, 10:35:05 AM
Re: Aquasport 281 ff
« Reply #1 on: December 12, 2014, 10:35:05 AM »
Sorry, we have no brochure but here's some light reading from an owner with this model.
Aqua250,
I own a 1988 281FF (Family Fisherman). In the 4 years I have owned her, the boat's primary use has been offshore fishing, ranging to islands (about 45 miles out) or open water, up to 55-60 miles offshore. It's well suited for purpose, carrying 2 to 4 people, full fuel load plus 65 gallon live bait tank (commonplace for SoCal style offshore fishing) plus tackle and supplies.
My 281FF has a hardtop with removable curtains all around. The back curtains are usually removed when boating, re-installed for storage. I don't know if the top was a factory option, but none of the 281 photos in the 1988 Aquasport brochure show a top. In my opinion, an enclosure of some type is essential for offshore use; the ride can be wet if swells come up when heading "uphill".
My boat is a single-inboard, powered by the original gas-burning carbureted Volvo Penta BB260: 350 cubic inches, rated 260 HP. At 4400 (maximum) RPM, the boat has a flat water top speed around 29 MPH. Fully loaded (4 people, full fuel, etc.) she cruises at 22 MPH at 3400 RPM, 24 MPH at 3600 RPM. From the specifications offered below, standard power was probably the 454 c.i. Volvo Penta. With today's fuel costs, I am glad she has the "small block" engine instead of the standard "big block".
Looking at Aquasport's brochure for that model year, there are differences in specifications between 1987 281 Osprey, and the two 281 models offered in 1988: the 281C (Coho) and the 281FF (Family Fisherman). The 281C has a "no frills" cabin, while the 281FF adds a deck hatch, a port hole on each side of the cabin, a head and holding tank. Neither model has a sink, so fresh water storage doesn't apply in 1988. Apparently the 1987 271 Osprey had a sink.
Standard power for the 281C/281FF was single inboard, There was also an option for outboard engine transom bracket. Big difference in fuel capacity, as you might guess.
Here are the 1988 specifications, direct from the Aquasport brochure:
Length including pulpit: 28' 10"
Beam: 9' 7-1/2"
Deadrise: 20 degrees
Hull Type: Deep V
Max HP: 550
Standard HP: 330 HP I/B
Approx. Dry Weight: 5400 lbs
Headroom: 6' 3"
Fuel Capacity: 150 gal Inboard, 250 gal Outboard
Draft (incl prop): 29"
I hope this helps,
Gary
Here's the other model he mentions (Coho)
If I understand correctly, the C and FF models are somewhat similar in appearance with the FF having a few extra goodies so that a Coho is a stripped down FF.
This may be the first link boat but it appears the links are broken to the additional photos and the ones shown are not good.
<!-- m -->http://www.boatsville.com/boats/CA/Hunt ... port/13041<!-- m -->
Couple of pics here.
<!-- m -->http://www.lakeontariounited.com/fishin ... offer-35k/<!-- m -->
<!-- m -->http://www.yachtworld.com/boats/1988/Aq ... IsTtMlvAjE<!-- m -->
December 12, 2014, 07:43:28 PM
« Reply #2 on: December 12, 2014, 07:43:28 PM »
Geez Bob, slow day at the office? Nice super sluething on this  :salut:
I had forgotten about his post way back when.
Nice Job buddy.
December 12, 2014, 10:47:10 PM
« Reply #3 on: December 12, 2014, 10:47:10 PM »
Like a dog on a bone.
How he finds this stuff, haven't a clue. Rick, keep him on the payroll :mrgreen:
Great job CB :salut:
May 31, 2016, 09:57:09 PM
John16066
« Reply #4 on: May 31, 2016, 09:57:09 PM »
Do you happen to have a capacity  plate on your boat. Mine is missing and trying to get info on it to get another one.
Thank you
John
May 31, 2016, 10:16:49 PM
« Reply #5 on: May 31, 2016, 10:16:49 PM »
Federal law requires hulls to 20' in length to carry a capacity plate. That stated,NMMA requires plates on hulls to 26' to be certified by their association (National Marine Manufacturers Association) so....
While I have not seen a plate for the 281, that certainly doesn't mean it never had one. Still, there's a fair chance Aquasport didn't plate the hull.
I'll look some more.
PS..."aqua" visited in early May of this year so he may respond.
Good luck. :thumright:
June 01, 2016, 12:38:49 PM
John16066
« Reply #6 on: June 01, 2016, 12:38:49 PM »
thank you So you are saying that it may not need a capacity plate ?
So if that is the case do i need to get it certified ?
And where does someone get that done ?
Thank you
John
June 01, 2016, 01:15:59 PM
« Reply #7 on: June 01, 2016, 01:15:59 PM »
Yes, under Federal law, your hull is not required to carry a USCG capacity plate.
No, I would think that is more geared toward the hull manufacturer. Like having a UL Approved sticker on an electrical cord. Gives the buyer a higher confidence level in the product's construction and safety standards.
I'm not sure a second party (Dealer) or third party purchaser/ hull owner could do that. Again, I'm not really sure but I see no advantage in trying myself.
Just thinking out loud.
