22-2 Rebuilds
'76 22 Osprey re-build
23
24
25
26
30
Topic: '76 22 Osprey re-build (Read 22763 times)
September 18, 2017, 05:02:57 PM
Reply #345
Que Pasa
NorthEast
Re: '76 22 Osprey re-build
Reply #345 on:
September 18, 2017, 05:02:57 PM »
Thank heaven for shrink wrap!
September 22, 2017, 05:30:30 PM
Reply #346
Que Pasa
NorthEast
Reply #346 on:
September 22, 2017, 05:30:30 PM »
Has anyone sand off the diamond plate on the casting platform? I'm wondering id the glass is thick enough to sand the texture off and then do non skid.
September 22, 2017, 06:17:33 PM
Reply #347
Reply #347 on:
September 22, 2017, 06:17:33 PM »
I did - the pattern isn't that thick so no need to go crazy on it - figure 20 mils maybe?
September 22, 2017, 08:44:06 PM
Reply #348
Que Pasa
NorthEast
Reply #348 on:
September 22, 2017, 08:44:06 PM »
So it is doable Rick?
September 22, 2017, 08:52:36 PM
Reply #349
Que Pasa
NorthEast
Reply #349 on:
September 22, 2017, 08:52:36 PM »
Got my floor tabbed in, I now believe I'm making progress.
September 23, 2017, 12:31:01 AM
Reply #350
Que Pasa
NorthEast
Reply #350 on:
September 23, 2017, 12:31:01 AM »
Rick isn't 20 mils like 3/4 of an inch? It cant be that deep.
September 23, 2017, 06:19:53 AM
Reply #351
Reply #351 on:
September 23, 2017, 06:19:53 AM »
Yeah you're right
I think I aimed for 10 mils when I was spraying my gelcoat and then sanded a lot of that off to get it shiny - so about 1/32" or less is how thick the non-skid is, on top of the gelcoat. I sanded mine down and then non-skid was applied (gelcoat and glass bead).
September 23, 2017, 02:02:59 PM
Reply #352
Que Pasa
NorthEast
Reply #352 on:
September 23, 2017, 02:02:59 PM »
When I sanded out my liner sides, I had a ton of voids. I'm worried that if I sand out the casting platform that deep I'm going to run into more of the same. My question is was there still plently of glass left for strength?
September 23, 2017, 09:49:35 PM
Reply #353
Reply #353 on:
September 23, 2017, 09:49:35 PM »
You shouldn't have a problem. The non skid is molded in the gel coat. I doubt that you will need to grind into glass very much if at all.
September 25, 2017, 06:10:23 PM
Reply #354
Que Pasa
NorthEast
Reply #354 on:
September 25, 2017, 06:10:23 PM »
Anyone, whats your transom angle on you 22.2?
September 26, 2017, 05:18:23 PM
Reply #355
theFunsmith
Reply #355 on:
September 26, 2017, 05:18:23 PM »
I measured my '76 at 15 degrees.
September 26, 2017, 07:31:28 PM
Reply #356
Que Pasa
NorthEast
Reply #356 on:
September 26, 2017, 07:31:28 PM »
That's strange, mine measured 3 1/4 inches, which is 13 degrees.
September 26, 2017, 07:55:12 PM
Reply #357
Reply #357 on:
September 26, 2017, 07:55:12 PM »
Quote from: Que Pasa on September 26, 2017, 07:31:28 PM
Different animal, but my 1979 CCP measured 13 degrees too.
September 26, 2017, 10:42:42 PM
Reply #358
theFunsmith
Reply #358 on:
September 26, 2017, 10:42:42 PM »
I just went out to measure again. Mine is was an inboard originally if that helps. I've got 3.5" from the bottom of the trasnom to the inside of the square using the 14" inside-16" outside end of the square. I guess that puts me closer to 14 degrees.
September 27, 2017, 08:49:34 AM
Reply #359
Que Pasa
NorthEast
Reply #359 on:
September 27, 2017, 08:49:34 AM »
I guess they all can vary a degree or so. They do tell you to take the bottom of the square out to 22 inches minimum. I guess to rule out interference from a hook.
23
24
25
26
30
22-2 Rebuilds
