Author Topic: '76 22 Osprey re-build  (Read 22898 times)
September 29, 2015, 02:42:47 PM
Reply #195
northfork
Re: '76 22 Osprey re-build
« Reply #195 on: September 29, 2015, 02:42:47 PM »
I cut a 3" PVC pipe in half and will glass that down instead. I cant see how that center stringer did much. With my overlaps I have 3 additional layers of 1708
along the keel. Hurry up I guess we have some bad weather coming this week.
September 29, 2015, 06:41:16 PM
Reply #196
Que Pasa
  • NorthEast
« Reply #196 on: September 29, 2015, 06:41:16 PM »
Only got the inside of the port stringer and the inner hull betwen the stringers so far. got 12 hours under my belt already. Slow goin, grinding sucks, my ears are ringing.
September 29, 2015, 06:42:24 PM
Reply #197
Que Pasa
  • NorthEast
« Reply #197 on: September 29, 2015, 06:42:24 PM »
By the way, what good is the pvc doing?
September 29, 2015, 07:08:24 PM
Reply #198
« Reply #198 on: September 29, 2015, 07:08:24 PM »
I put it in to support the tank
The center one allows water to run from front to back
Look through this prtion of my rebuild
http://classicaquasport.com/smf/index.php?topic=10101.msg106490#msg106490
September 30, 2015, 04:31:52 PM
Reply #199
Que Pasa
  • NorthEast
« Reply #199 on: September 30, 2015, 04:31:52 PM »
How about some help on the transom knees. I will be joining them to the original stringers. I was thinking of using 1 in coosa. Any Ideas?
September 30, 2015, 04:44:39 PM
Reply #200
« Reply #200 on: September 30, 2015, 04:44:39 PM »
Take a peek in the FB rebuild forum and look at how some of the rebuilders did theirs - I didn't close in my transom.
September 30, 2015, 05:40:28 PM
Reply #201
northfork
« Reply #201 on: September 30, 2015, 05:40:28 PM »
This is how I did my knees. I had 1 3/4" Coosa left over from the transom.
September 30, 2015, 05:56:16 PM
Reply #202
Que Pasa
  • NorthEast
« Reply #202 on: September 30, 2015, 05:56:16 PM »
Thanks Rick I did look, but found this may be easier.
September 30, 2015, 05:57:54 PM
Reply #203
Que Pasa
  • NorthEast
« Reply #203 on: September 30, 2015, 05:57:54 PM »
North will you be extending the original stringer back? I also want to extend it up the support my cap.
September 30, 2015, 06:08:22 PM
Reply #204
northfork
« Reply #204 on: September 30, 2015, 06:08:22 PM »
Que
I am not extending the existing stringers back. I glassed the back sides solid. I am going to extend the line of the knees up to the cap with corelite. I had coosa left over and that was as high as I could make them. All the force is well below the tops as it is now. I am going to engage the deck with the knees and the transom and that will be overkill.
September 30, 2015, 06:41:23 PM
Reply #205
« Reply #205 on: September 30, 2015, 06:41:23 PM »
Here is a pic from Craig's rebuild
http://classicaquasport.com/smf/index.php?topic=10287.msg108342#msg108342
Built like an M-1 Abrams tank  :thumleft:
September 30, 2015, 07:16:05 PM
Reply #206
Que Pasa
  • NorthEast
« Reply #206 on: September 30, 2015, 07:16:05 PM »
Thanks guys, do you think 1 inch cooosa would be sufficient. Of course tabbed in with 3 layers.
September 30, 2015, 07:32:18 PM
Reply #207
« Reply #207 on: September 30, 2015, 07:32:18 PM »
Can you double it?
September 30, 2015, 08:27:44 PM
Reply #208
Que Pasa
  • NorthEast
« Reply #208 on: September 30, 2015, 08:27:44 PM »
I have 1/2 inch and was going to double that with a layer of 1708 between.
October 01, 2015, 05:42:59 AM
Reply #209
« Reply #209 on: October 01, 2015, 05:42:59 AM »
Looks like Aaron used 3/4" penske and tied it into the hull well
http://classicaquasport.com/smf/index.php?topic=9842.msg114017#msg114017
Here is Chris's knees - 1" Corecell with lots of glass
Quote
the knees are more there for forming a box to hide rigging than anything
http://classicaquasport.com/smf/index.php?topic=4582.msg39769#msg39769
Maybe they can talk about what the intent of their construction plan was at the time.
