Author Topic: '76 22 Osprey re-build  (Read 22784 times)
May 16, 2016, 06:53:07 PM
Reply #300
Que Pasa
  • NorthEast
Re: '76 22 Osprey re-build
« Reply #300 on: May 16, 2016, 06:53:07 PM »
Putting the stringer caps on, what a pain in the ass. The starboard stringer is up to 3/4 of an in inch lower than the port at the bow. Looks like they leveled it with the wiring troft. That's why I had to grind all that bondo off the stringer. Trying to get the stringers level is frustrating.
May 19, 2016, 11:56:16 AM
Reply #301
kidd277
« Reply #301 on: May 19, 2016, 11:56:16 AM »
Que, i may have missed it when reading through your post but what material did you build your stringer caps out of?
May 19, 2016, 10:38:07 PM
Reply #302
Que Pasa
  • NorthEast
« Reply #302 on: May 19, 2016, 10:38:07 PM »
2 layers of 3/4 inch coosa, they should be glassed in tomorrow
May 21, 2016, 09:14:01 AM
Reply #303
Que Pasa
  • NorthEast
« Reply #303 on: May 21, 2016, 09:14:01 AM »
Got the stringer caps glassed in finally. 2 layers 3/4" coosa. So now the stringers have 3 layers of 1708, should be pretty stout.
June 08, 2016, 08:28:24 AM
Reply #304
Que Pasa
  • NorthEast
« Reply #304 on: June 08, 2016, 08:28:24 AM »
Can anyone tell me about the bolt pattern ffor a Porta bracket. Do any of the bolts fall outsde of the stringers?
June 08, 2016, 08:19:52 PM
Reply #305
« Reply #305 on: June 08, 2016, 08:19:52 PM »
Do a search on here for "Porta bracket mounting template".  Your work looks great!
June 08, 2016, 09:46:06 PM
Reply #306
Que Pasa
  • NorthEast
« Reply #306 on: June 08, 2016, 09:46:06 PM »
Thanks CLM been long hard road. I cant seem to find anything in the search.
June 08, 2016, 10:42:40 PM
Reply #307
« Reply #307 on: June 08, 2016, 10:42:40 PM »
Sorry, only seems to work if you leave out "mounting".  Here is the link.
http://classicaquasport.com/smf/index.php?topic=12160.msg122457#msg122457
Bottom line, it fits between the stringers.
June 09, 2016, 08:19:26 AM
Reply #308
Que Pasa
  • NorthEast
« Reply #308 on: June 09, 2016, 08:19:26 AM »
Thanks CLM, Hope the bolt lines up above and below the floor support too.
June 20, 2016, 06:07:40 PM
Reply #309
Que Pasa
  • NorthEast
« Reply #309 on: June 20, 2016, 06:07:40 PM »
Got a little more done, fuel tank, wiring chases and bilge painted. Now ready to start the patterning for the floor. Onward and upward.
June 20, 2016, 07:23:58 PM
Reply #310
« Reply #310 on: June 20, 2016, 07:23:58 PM »
Looking good QP !!
June 21, 2016, 10:07:13 AM
Reply #311
northfork
« Reply #311 on: June 21, 2016, 10:07:13 AM »
Looking real good. What are you going to use for the deck material.
Do you have any pictures of how you mounted the tank.
June 21, 2016, 09:14:49 PM
Reply #312
Que Pasa
  • NorthEast
« Reply #312 on: June 21, 2016, 09:14:49 PM »
North I used Pascoes method. I glued (5200) 4 two inch strips length wise on the bottom of the tank. I had feet welded on the four corners of the tank, I glued (5200) the tank to the cradle allowing it to form a gasket. I then came back after the gasket formed and drilled the feet and screwed them into the glass.
June 21, 2016, 09:19:14 PM
Reply #313
northfork
« Reply #313 on: June 21, 2016, 09:19:14 PM »
Nice that's what I did on my tank replacement on my Mako this past winter. So far so good.
June 21, 2016, 09:44:53 PM
Reply #314
Que Pasa
  • NorthEast
« Reply #314 on: June 21, 2016, 09:44:53 PM »
I switched out the corelite and I will be going with the Coosa for the deck. The corelite was just to heavy.
