22-2 Rebuilds
'76 22 Osprey re-build
16
17
18
19
30
Topic: '76 22 Osprey re-build (Read 21819 times)
November 03, 2015, 01:14:17 PM
Reply #240
northfork
Re: '76 22 Osprey re-build
Reply #240 on:
November 03, 2015, 01:14:17 PM »
Yes Bob that was the company. Phil is really nice to work with. Seems to be the go to guy up here.
November 03, 2015, 02:44:04 PM
Reply #241
Que Pasa
NorthEast
Reply #241 on:
November 03, 2015, 02:44:04 PM »
Thanks guys, I was looking at poly since I wasn't going with a deck hatch. Dont the aluminum ones need to be sealed with glass?
November 03, 2015, 04:51:12 PM
Reply #242
Reply #242 on:
November 03, 2015, 04:51:12 PM »
If you have good airflow around an aluminum tank you don't have to do anything to them.
November 03, 2015, 05:02:00 PM
Reply #243
Global Moderator
Reply #243 on:
November 03, 2015, 05:02:00 PM »
Quote from: Que Pasa on November 03, 2015, 02:44:04 PM
You plan to install below deck and cover over with no access, correct?
November 03, 2015, 08:08:27 PM
Reply #244
Que Pasa
NorthEast
Reply #244 on:
November 03, 2015, 08:08:27 PM »
Yes
November 04, 2015, 09:09:54 AM
Reply #245
Global Moderator
Reply #245 on:
November 04, 2015, 09:09:54 AM »
Well then, since you're sealing the tank in, poly might give you a longer life because it will sweat under there.
As stated in other rebuilds, allow for expansion and mount it accordingly. We've seen poly tanks chafe when
not secured properly and end up leaking way before their lifetime.
November 04, 2015, 11:01:34 AM
Reply #246
Que Pasa
NorthEast
Reply #246 on:
November 04, 2015, 11:01:34 AM »
Thanks Bob, but after searchin the net for a poly tank I finally gave up and ordered a custom aluminum.
November 04, 2015, 11:03:35 AM
Reply #247
Que Pasa
NorthEast
Reply #247 on:
November 04, 2015, 11:03:35 AM »
Does anyone have the measurement of the original console base from the casting platform. I seem to have lost mine, I thought I gave it to north but cant seem to find it in the thread.
November 04, 2015, 11:26:32 AM
Reply #248
northfork
Reply #248 on:
November 04, 2015, 11:26:32 AM »
Que
I have the measurement at home in my log book. I will send it later.
November 04, 2015, 03:23:44 PM
Reply #249
Que Pasa
NorthEast
Reply #249 on:
November 04, 2015, 03:23:44 PM »
thanks north starting to plan out my floor
November 04, 2015, 04:46:15 PM
Reply #250
northfork
Reply #250 on:
November 04, 2015, 04:46:15 PM »
Que
Are you using your old console?
Who did you order your tank from?
North
November 04, 2015, 05:03:56 PM
Reply #251
Que Pasa
NorthEast
Reply #251 on:
November 04, 2015, 05:03:56 PM »
North yes I'm redoing the old console, going for the original look, no tower or t-top. And The tank is being made custom by a metal shop a friend of mine owns. It'll be 80 x 24 x 9, 76 gal.
November 05, 2015, 04:34:20 PM
Reply #252
Que Pasa
NorthEast
Reply #252 on:
November 05, 2015, 04:34:20 PM »
Looking for opinions on my floor, I dont plan on adding a tower or t-top. I was going to raise the floor 3 inches, I'm wondering if I can get away with 1 1/2"?
November 06, 2015, 10:48:00 AM
Reply #253
northfork
Reply #253 on:
November 06, 2015, 10:48:00 AM »
Que
The console was set back from the face of the front casting deck 28 1/2". (Not the lip the front face of the console)
I'm going up 1 1/2" on my deck as well unless I hear anything from others that it should go higher.
I made my new tank 84" long.
Chuck
November 08, 2015, 06:23:28 PM
Reply #254
Que Pasa
NorthEast
Reply #254 on:
November 08, 2015, 06:23:28 PM »
Gran, how far forward did you move your fuel tank? And do you feel you placed it right.
16
17
18
19
30
22-2 Rebuilds
