Author Topic: '76 22 Osprey re-build  (Read 22844 times)
July 29, 2015, 07:59:15 AM
Reply #165
Que Pasa
  • NorthEast
Re: '76 22 Osprey re-build
« Reply #165 on: July 29, 2015, 07:59:15 AM »
whats a good material
July 29, 2015, 09:41:52 AM
Reply #166
« Reply #166 on: July 29, 2015, 09:41:52 AM »
You want something that will hold a screw unless you are going to thru-bolt everything.  Nothing wrong with plywood again if you seal it correctly and then seal the holes when you drill into it.  It'll outlast you.
July 29, 2015, 10:59:41 AM
Reply #167
Que Pasa
  • NorthEast
« Reply #167 on: July 29, 2015, 10:59:41 AM »
I'd like to try and keep the weight down, so I want to go with somthing lighter.
July 29, 2015, 12:20:25 PM
Reply #168
northfork
« Reply #168 on: July 29, 2015, 12:20:25 PM »
Que
I am going to use 1/2" plywood. There isn't much material so not sure how much wt. you are going to save. I am looking forward to see what you are doing with the transom cap. I have been grinding the center portion of the interior of the hull. Now ready to add glass and bulkheads. Outside of stringers and up the chine done.
How was it removing the cap?
July 29, 2015, 05:52:54 PM
Reply #169
Que Pasa
  • NorthEast
« Reply #169 on: July 29, 2015, 05:52:54 PM »
Hey North, looks like I'll be going with divinycell. I really don't want anymore wood in the boat. The cap was pretty  easy, had to grind a couple but not to many. I built the form while it was on the boat just a simple structure to support the curve. Had 4 people and we did just fine wasn't that heavy. Now the grinding begins again as the whole core is rotted.
July 29, 2015, 06:07:13 PM
Reply #170
northfork
« Reply #170 on: July 29, 2015, 06:07:13 PM »
I only have one place that needs to be repaired on the cap. All the rest looks good on mine. I might try to get at it on the boat. One step at a time. Want to get ready for the deck and we will see. Gotta get a fuel tank very soon.
August 06, 2015, 12:55:12 PM
Reply #171
northfork
« Reply #171 on: August 06, 2015, 12:55:12 PM »
Hows that cap coming out.
August 08, 2015, 12:33:44 AM
Reply #172
Que Pasa
  • NorthEast
« Reply #172 on: August 08, 2015, 12:33:44 AM »
been really busy, but just started grinding today. should be done manana.
September 14, 2015, 07:20:46 PM
Reply #173
Que Pasa
  • NorthEast
« Reply #173 on: September 14, 2015, 07:20:46 PM »
Got rolling on the cap, 1/2 done. Side two tomorrow.
September 14, 2015, 08:28:57 PM
Reply #174
« Reply #174 on: September 14, 2015, 08:28:57 PM »
Keep it rolling  :thumleft:
September 15, 2015, 11:31:30 AM
Reply #175
northfork
« Reply #175 on: September 15, 2015, 11:31:30 AM »
looking good
progress is a good thing
Northfork
September 15, 2015, 07:45:40 PM
Reply #176
Que Pasa
  • NorthEast
« Reply #176 on: September 15, 2015, 07:45:40 PM »
Cap coring is complete.
September 15, 2015, 07:59:23 PM
Reply #177
« Reply #177 on: September 15, 2015, 07:59:23 PM »
Looks like it'll be nice and stout.   :thumleft:
Looks like it'll be a close fit along the sides.
September 15, 2015, 09:06:03 PM
Reply #178
Que Pasa
  • NorthEast
« Reply #178 on: September 15, 2015, 09:06:03 PM »
Yep in that one section, noting the proper size bolts wont fix. :acclaim01:
September 22, 2015, 07:35:42 PM
Reply #179
Que Pasa
  • NorthEast
« Reply #179 on: September 22, 2015, 07:35:42 PM »
Cap is on, not to bad either. Solid as rock, all cuts for transom cap section look good and line up perfectly. Now on to the floor, cutting will start in the am, hoping for no surprises.
