Author Topic: '76 22 Osprey re-build  (Read 22853 times)
July 19, 2015, 07:37:17 PM
Reply #150
Que Pasa
  • NorthEast
Re: '76 22 Osprey re-build
« Reply #150 on: July 19, 2015, 07:37:17 PM »
Has anyone used Azek board on top of stringers for backing for tower and console?
July 19, 2015, 07:50:49 PM
Reply #151
« Reply #151 on: July 19, 2015, 07:50:49 PM »
The best thing for tower installs is thru-bolting it through something OR putting some metal plating down under the sole, drill and tapping the holes.
IMO the composite boards like Azek and Trex are not strong enough to trust screwing into them with lags or something like that to anchor a t-top or tower. It may be ok for a console unless it is the main thing to grab onto in the boat. I have some trex in the bilge of my 230 holding the 40gal freshwater tank in place.  I thru-bolted everything and the material has held up well for 8 or so years.
You can try some tests to see if it'll hold a lag.
July 19, 2015, 09:14:17 PM
Reply #152
Que Pasa
  • NorthEast
« Reply #152 on: July 19, 2015, 09:14:17 PM »
I am using it for my bilge drain plug knotch and I may use it to support my floor on top of stringers, since I'll only be setting a console.
July 20, 2015, 09:45:33 PM
Reply #153
Que Pasa
  • NorthEast
« Reply #153 on: July 20, 2015, 09:45:33 PM »
Ready for glass, really happy it straight as an arrow.
July 21, 2015, 04:59:52 AM
Reply #154
« Reply #154 on: July 21, 2015, 04:59:52 AM »
 :thumleft:
July 21, 2015, 10:54:52 AM
Reply #155
northfork
« Reply #155 on: July 21, 2015, 10:54:52 AM »
Que
Looks good.
July 22, 2015, 11:00:15 AM
Reply #156
Que Pasa
  • NorthEast
« Reply #156 on: July 22, 2015, 11:00:15 AM »
Transom done, now on to bigger and better things. lol. 3 more layers of 1708 4,6,9 inch tabs. Que pasa amigo.
July 22, 2015, 01:37:44 PM
Reply #157
northfork
« Reply #157 on: July 22, 2015, 01:37:44 PM »
Time to rip that deck out. Whats your plan on the stringers. Are you going to remove the foam?
July 22, 2015, 04:53:44 PM
Reply #158
Que Pasa
  • NorthEast
« Reply #158 on: July 22, 2015, 04:53:44 PM »
North, I will do the cap next. Then on to the stringers and yes the foam is coming out. I'm thinking corecell for the floor and bulkhead the seams.
July 28, 2015, 05:31:02 PM
Reply #159
Que Pasa
  • NorthEast
« Reply #159 on: July 28, 2015, 05:31:02 PM »
What is everyone coring their caps with?
July 28, 2015, 07:17:08 PM
Reply #160
« Reply #160 on: July 28, 2015, 07:17:08 PM »
I recored the front of my cap only, the rest wasn't cored.  I used Plascore and where I was going to through bolt things I used some coosa that Gran sent me.
July 28, 2015, 08:35:52 PM
Reply #161
Que Pasa
  • NorthEast
« Reply #161 on: July 28, 2015, 08:35:52 PM »
Thanks looked like mine had 1/4" ply that was covered with mat. All rotted out. So you just cored where the rod holders were and the fore deck.
July 28, 2015, 08:40:00 PM
Reply #162
« Reply #162 on: July 28, 2015, 08:40:00 PM »
My rod holders are metal plates, so no backing needed.
http://classicaquasport.com/smf/index.php?topic=10101.660
July 28, 2015, 09:28:38 PM
Reply #163
Que Pasa
  • NorthEast
« Reply #163 on: July 28, 2015, 09:28:38 PM »
Do  you think my cap will be strong enough without coring? I dont think your cap is the same, you have a little more support from your liner.
July 29, 2015, 05:25:22 AM
Reply #164
« Reply #164 on: July 29, 2015, 05:25:22 AM »
If the coring is rotted out, replace it.  Looks like you have the curve locked into the cap so you should be good to go while recoring.
