Author Topic: 91 Johnson 70hp slipping in higher rpm's  (Read 411 times)
November 08, 2014, 07:59:31 PM
Read 411 times
Captain Bart
  • REGISTERED
« on: November 08, 2014, 07:59:31 PM »
I have a 1991 Johnson 70 hp on my 1986 170.  I was out running on a plane today when all of a sudden the rpm shot up and the boat came off a plane.  I thought I hit a sandbar but I was in the middle of the ICW.  I trim the engine down and went to get back on a plane an as soon as the rpm's got up to about 3000 the engine would rev and I had no thrust.  I idled over to a spoil island and checked the prop to see if it was slipping but it was solid.  The controls seem to be working and I can shift through forward, neutral and reverse.  If anyone has any clues, hints or tips, I sure could use them.
1986 170 w/ Johnson 70
November 09, 2014, 07:05:27 AM
Re: 91 Johnson 70hp slipping in higher rpm's
« Reply #1 on: November 09, 2014, 07:05:27 AM »
Sure sounds like you "spun the hub" to me.  I think it's time to get the prop rehubbed.
November 09, 2014, 08:26:02 AM
Captain Bart
  • REGISTERED
« Reply #2 on: November 09, 2014, 08:26:02 AM »
I hope your right.  I just could not get it to slip when I manually checked.  I was going to re prop her anyway, so new hub and prop, hopefully that works. I have a 13x17p on there now with a slight cup.  I was going to stay with the same but I was told by a mechanic that it was a little large for my engine. I'm not so sure before the problem, I was getting about 30 mph at around 5800 rpms.
November 09, 2014, 09:03:50 AM
« Reply #3 on: November 09, 2014, 09:03:50 AM »
Spun hub, you don't have to hit something for them to let go either. Water skiers run into this often. Often you can't tell its spun by checking it manually. When you pull the prop you'll see that rubber hub is separating from the metal insert and is chewed up. Your engine is propped perfectly at 5800 rpm. Stick with 17 pitch.
November 09, 2014, 09:27:36 PM
LiquidTherapy
« Reply #4 on: November 09, 2014, 09:27:36 PM »
Ya as others said, I had a old Century with twin yamahas. One was spun the other was ok. Side by side no difference. Rehub that bad boy!
November 10, 2014, 07:55:25 PM
Captain Bart
  • REGISTERED
« Reply #5 on: November 10, 2014, 07:55:25 PM »
Changed out the prop and yeah it was spun.  I took it to a mechanic because I didn't have a socket large enough to take off the bolt, but the mechanic who changed it said you didn't need a wrench and just tightened it by hand.  He said you just needed to hand tighten the bolt enough to line up the cotter pin, which keeps the prop on.
Is there any truth to that?
November 10, 2014, 10:38:15 PM
« Reply #6 on: November 10, 2014, 10:38:15 PM »
Quote from: "Captain Bart"
Maybe. :|
Wonder what the manual gives for a torque spec? Probably not real high so if you have strong fingers........
I'd still use a wrench and snug it down a tad (not too taddy) and line up the key.
November 11, 2014, 08:42:06 AM
futch13
« Reply #7 on: November 11, 2014, 08:42:06 AM »
Depending on prop nut, if it is a castle nut 120-144 in/lbs  if it is a regular nut with a s/s "keeper" (sleeve with grooves for cotter pin at top) then the torgue is 70-80 ft/lbs.  If cotter pin hole does not line up, tighten DO NOT loosen to align hole.
