Author Topic: Looked at another 1987 200  (Read 676 times)
October 27, 2014, 12:34:52 PM
Read 676 times
Slo Poke 1
« on: October 27, 2014, 12:34:52 PM »
This weekend.
https://tampa.craigslist.org/pnl/boa/4717609003.html
The aft inspection plate was replaced with an over sized plate to repair a soft spot.  The owner also repaired a soft spot behind the CC.  An area just forward of the inspection plate is soft as well as adjacent to the sport behind the CC.  I don't know if he is merely chasing soft spots or didn't seal his previous work properly and caused the new spots.  The rest of the deck and transom seem solid.
The manual jack plate was added since the 25" shaft was too long.  The trim tabs have been disconnected, but he said they work.  Has the windshield and railing stored (removed to clear low bridges).
He said the engine is a '94 and has been rebuilt.
Thoughts?
October 27, 2014, 01:55:14 PM
gman 82 aquasport
Re: Looked at another 1987 200
« Reply #1 on: October 27, 2014, 01:55:14 PM »
Not a bad price if he has receipts for the motor rebuild :salut: You can open up those larger inspection plates and get a mirror and a flashlight and check out the floor situation. Just lay on the floor and shine your light up in the hull and adjust the mirror to see the bottom of the floor. It should show the bad spots(look wet). If they have used more than 2 larger inspection plates to correct soft spots, walk the entire floor feeling for any abnormal give or bounce. If it's kind of bouncy all over but not real soft you may get a couple of years out of it before it needs replacing...Also if possible check the trough for holes. Mine had like 7 or 8 1/4 holes in it for old wiring that wasn't sealed.. Also check the tank inspection plate for the tank condition, looking for corrosion and coffin holding water.
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
October 27, 2014, 02:00:04 PM
« Reply #2 on: October 27, 2014, 02:00:04 PM »
I drove by that boat for sale on the side of Starky road last week.  I wish I had time to stop and look at it.
October 27, 2014, 04:48:50 PM
Slo Poke 1
« Reply #3 on: October 27, 2014, 04:48:50 PM »
Most of the deck had no give at all, just the 2 areas near previous repair.
The owner said bought the engine from a guy in Georgia that had it rebuilt. I'll check if he has documentation.
October 28, 2014, 12:29:13 PM
Slo Poke 1
« Reply #4 on: October 28, 2014, 12:29:13 PM »
He does not have the rebuild documentation, but does have service records.
October 28, 2014, 05:48:00 PM
Aquasport Commodore
« Reply #5 on: October 28, 2014, 05:48:00 PM »
That motor looks like it has the aftermarket extension on it like Grands does. If so that can be removed I would think and made into a 20" shaft and ditching the jack plate or using it to get skinny :) . Here is the link to the site http://www.baymfg.com
October 28, 2014, 07:26:46 PM
Slo Poke 1
« Reply #6 on: October 28, 2014, 07:26:46 PM »
I believe the owner bought that way and added plate due the length; how can I tell if the extension was added.
I want a 20" shaft and a hydraulic jack plate.
October 28, 2014, 08:03:03 PM
Aquasport Commodore
« Reply #7 on: October 28, 2014, 08:03:03 PM »
Look at the section where the lower attaches. Compare it to the link I sent or google the extension and you will see. Fritz is also a specialist on those from Grands. Here is a photo with the extensions installed. Compare them to that motor on the 200.
And the photo of from the add
October 28, 2014, 08:42:04 PM
« Reply #8 on: October 28, 2014, 08:42:04 PM »
Quote from: "Slo Poke 1"
This weekend.
I'm guessin' those photos are from another ad?????????? :scratch:
October 29, 2014, 08:17:24 AM
Slo Poke 1
« Reply #9 on: October 29, 2014, 08:17:24 AM »
Bob, I took those photos of the boat in the ad.
