Author Topic: Humminbird fisfinder  (Read 434 times)
October 18, 2014, 07:28:11 AM
Read 434 times
J Mac
« on: October 18, 2014, 07:28:11 AM »
I have a humminbird fishfinder on my 17.5. It has worked perfectly but this summer it just stopped displaying on screen. It make a faint beep when I try to power up but nothing come up just a blank screen. Is it time to replace. Can I just replace the unit and keep the rest or is it best to replace all parts
John
October 18, 2014, 07:42:47 AM
Re: Humminbird fisfinder
« Reply #1 on: October 18, 2014, 07:42:47 AM »
3, if you replace the head unit with an identical or similar model from the same vintage, it's just a matter of un-plugging the old, plugging in the new.  HB has been pretty good over the years in keeping the ducer and power supply plugs the same.  Check ebay for a replacement head unit, a lot of the ones for sale cheap on there don't come with the ducer or the power cord...which you don't need...
October 18, 2014, 10:20:02 AM
« Reply #2 on: October 18, 2014, 10:20:02 AM »
I would try and hook it up directly to a battery to see if that makes a difference. Could be corrosion in the wiring keeping it from getting full flow of juice.
November 30, 2014, 05:45:46 PM
« Reply #3 on: November 30, 2014, 05:45:46 PM »
Ditto on what Lewis said - check all the connections carefully - beep and off usually means low voltage.
November 30, 2014, 05:58:30 PM
« Reply #4 on: November 30, 2014, 05:58:30 PM »
Depending on model, Hummingbird has some fairly reasonable service costs and flat rates. In some cases, hundreds of dollars less than a new replacement. If you go to their website you can look up your model and determine the max service costs and decide the economics. If its 5 or 10 years old maybe not but its worth a look before tossing it.
