Author Topic: 1981 Aquasport 170 rebuild in Sweden  (Read 36340 times)
December 30, 2014, 10:42:58 AM
Reply #135
Re: 1981 Aquasport 170 rebuild in Sweden
« Reply #135 on: December 30, 2014, 10:42:58 AM »
Thanks Georgie, glad I did foam mine then  :icon_salut:
Lars, the transom looks great   :icon_cheers:
A question though, is that pipe for your shifting/throttle and engine controls?  Did you try to feed them through that sweep already?  I think there might be a problem making it through that 90.  I have 3" pipe anywhere the pipe makes a bend and 45s and it was tough to get the shifting and throttle through even with a 45.
December 30, 2014, 11:16:01 AM
Reply #136
larsli68
« Reply #136 on: December 30, 2014, 11:16:01 AM »
I will double check tomorrow regarding the bend radii on the throttle cable and shifter. I have the cables and will test. Good point, thanks.
The transom looks a bit spotty still, but I'm tickled to death over the result! It feels super strong already. I bet it will be the strongest transom in Sweden!
I added two layers of fiberglass 600g/m2 on the inside of the hull of the stringers, before closing them up. I might still foam the stringers.
The pipe bend I used is called a long bend. If I can't get the cables though, I will cut the inside radius and straighten it out with fiberglass. I will make it work.
Thanks for bringing it to my attention.
December 30, 2014, 09:00:17 PM
Reply #137
« Reply #137 on: December 30, 2014, 09:00:17 PM »
I fully agree with Ryan on the foam within the stringers, and will go a step further to recommend 4# density foam instead of 2#.  2# is quite compressible, and is typically recommended for flotation such as between the stringers, while 4# is recommended for inside the stringers, where strength is a little more important.
And good catch on the rigging tube, Rick.  Better to find out now if it will work or not.  I have some pretty tight bends in my tower, but I believe the Teleflex extreme cables that Seabob recommends can handle them.  I think they have a 4" or 5" bend radius.
December 31, 2014, 06:12:56 AM
Reply #138
larsli68
« Reply #138 on: December 31, 2014, 06:12:56 AM »
The rigging tube worked fine. Tested it this morning. Did three floor supports today. Will take it easy tonight (New Years Eve) and work again tomorrow.
I hope to fit the floor on Friday. :)
December 31, 2014, 08:10:09 AM
Reply #139
« Reply #139 on: December 31, 2014, 08:10:09 AM »
That's good.  So the control cables went through no problem?
December 31, 2014, 10:51:01 AM
Reply #140
larsli68
« Reply #140 on: December 31, 2014, 10:51:01 AM »
Yes, they went though fine.
I made 3 floor supports today. I will stay off the alcohol tonight and be able to work on the boat tomorrow. :)
I have to take the opportunity I have while I'm in the heated shop. I hope to fit the floor on Friday. I have gotten a lot done the past 8 days.
December 31, 2014, 11:03:40 AM
Reply #141
dburr
« Reply #141 on: December 31, 2014, 11:03:40 AM »
Lars, you're killing it!! What an animal!
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
December 31, 2014, 11:06:48 AM
Reply #142
« Reply #142 on: December 31, 2014, 11:06:48 AM »
Glad to hear the control cables go through fine.  Looking real good.  Happy New Year.
December 31, 2014, 11:32:25 AM
Reply #143
larsli68
« Reply #143 on: December 31, 2014, 11:32:25 AM »
Thanks Dave,
I will mark my stringers and be able to foam them even after I have installed the floor.
I hope to have another 5 days before I'm out of the heated shop. I need to get pretty much all the fiberglass work done in that time.
Wet sanding the hull, polishing and refit I can do at home in the spring. Still three months before boating season here in Sweden...
Happy New Year!!!
January 01, 2015, 10:26:14 AM
Reply #144
larsli68
« Reply #144 on: January 01, 2015, 10:26:14 AM »
Spent a sober New Years Eve to be able to work on the boat today. I know I'm crazy, but I want to use every hour I can be in the heated shop.
I glassed some support for the gas tank today. Cut the gas tank hatch in the floor and glassed an edge for the hatch cover to rest on. It is easy to do this while the floor is still on the table.
I also painted some top coat in the rear bilge area.
January 03, 2015, 12:07:38 AM
Reply #145
larsli68
« Reply #145 on: January 03, 2015, 12:07:38 AM »
Worked on the boat again yesterday. Put in almost 9 hours of work. A push to get the floor installed while there were people in the shop.
January 03, 2015, 05:28:47 AM
Reply #146
« Reply #146 on: January 03, 2015, 05:28:47 AM »
Nice progress Lars  :icon_salut:
So how did the shop guys like working with the Seacast product?
January 03, 2015, 09:07:36 AM
Reply #147
larsli68
« Reply #147 on: January 03, 2015, 09:07:36 AM »
Hello Rick,
They thought it was a cool product. Easy to use if you prepare and get all the wood and moisture out of your transom.
My transom feels like a rock now. I capped the transom today. Two hours worth of grinding and then glassing over the top. I will grind and start to make it look pretty tomorrow. There is no upload button for pics right now.
January 03, 2015, 11:31:19 AM
Reply #148
« Reply #148 on: January 03, 2015, 11:31:19 AM »
Lars, make sure you're logged in on the gallery.  Look at the top left and see if it has a login button or not.  I have an upload button.
January 03, 2015, 12:23:11 PM
Reply #149
larsli68
« Reply #149 on: January 03, 2015, 12:23:11 PM »
I am logged in, but no upload button. I have tried both Chrome and Firefox browsers.
Do you have any ideas what to try next? I tried logging off and back on, but still no upload button.
