165/170/175 Rebuilds
1981 Aquasport 170 rebuild in Sweden
36
37
45
Topic: 1981 Aquasport 170 rebuild in Sweden (Read 34519 times)
June 06, 2016, 01:02:49 PM
Reply #510
Re: 1981 Aquasport 170 rebuild in Sweden
Reply #510 on:
June 06, 2016, 01:02:49 PM »
June 06, 2016, 03:28:05 PM
Reply #511
larsli68
Reply #511 on:
June 06, 2016, 03:28:05 PM »
Thanks Rick!
I really want to launch. It's just that so much other stuff comes in the way...
//Lars
June 06, 2016, 04:03:53 PM
Reply #512
Reply #512 on:
June 06, 2016, 04:03:53 PM »
Quote from: larsli68 on June 06, 2016, 03:28:05 PM
Thanks Rick!
//Lars
Tell me about it
(I know the feeling)
June 08, 2016, 04:01:49 PM
Reply #513
larsli68
Reply #513 on:
June 08, 2016, 04:01:49 PM »
Well, baby steps towards launch... My brother and nephew helped me move the Merc up two holes tonight. Together with the new Mercury Vengeance 18" pitch prop, I'm hoping to get
another 4 knots out of the motor. All according to my mechanic and racer buddy.
Launch is now planned for Friday afternoon or Saturday morning. All depends on the weather.
//Lars
June 11, 2016, 08:11:38 AM
Reply #514
larsli68
Reply #514 on:
June 11, 2016, 08:11:38 AM »
Finally launched today. Tested the new prop, and had some vibrations unfortunately... Not fun, but I switched back to the 17" pitch alu prop and the problem went away.
I will try to get the stainless steel prop balanced.
June 11, 2016, 09:04:36 AM
Reply #515
Reply #515 on:
June 11, 2016, 09:04:36 AM »
Weather looks great in that shot - plus you got her launched and can enjoy her now for a while.
June 11, 2016, 10:27:53 AM
Reply #516
larsli68
Reply #516 on:
June 11, 2016, 10:27:53 AM »
Hello Rick,
The weather has been a bit on and off today. I did take her out for a spin. GPS worked fine. Will do more tomorrow.
I'm a bit bummed over the Stainless steel prop... I will take it to a prop shop to get it fixed.
June 12, 2016, 03:06:15 AM
Reply #517
larsli68
Reply #517 on:
June 12, 2016, 03:06:15 AM »
I have a question. I'm thinking of using the new prop center adapter from the alu prop on my stainless steel prop today.
I used the center adapter that came with the stainless steel (used prop). I might try this today.
June 12, 2016, 04:58:43 AM
Reply #518
Mechanical Master
Reply #518 on:
June 12, 2016, 04:58:43 AM »
Hi Lars,
Are you talking about the flo-torque center adapter? I'm assuming they are both the flo- torque II. Is it plastic or brass? There are different adapters for different props assuming the stainless prop is Mercury. Some use the flo- torque III or IV so make sure you use the correct adapter. This may be the cause of the vibration. Also make sure that you torque the prop nut to 55 foot pounds, if it's just snugged up it can vibrate.
June 12, 2016, 07:16:51 AM
Reply #519
larsli68
Reply #519 on:
June 12, 2016, 07:16:51 AM »
Thanks for the input!
I tried to use the torque adapter from the Alu prop (Merc) but the same vibration occurred. Now I'm back on the 17" prop, and will have to take this stainless Vengeance prop to a prop shop.
No such thing in my home town, but I will bring it to Stockholm or Gothenburg.
We went for a small swing today. Posting some pictures.
June 12, 2016, 08:44:39 AM
Reply #520
larsli68
Reply #520 on:
June 12, 2016, 08:44:39 AM »
I have this kit. #835257K1
Everything fits just fine, feels solid, but the prop gives a weird noise when as soon as I put it in gear.
June 12, 2016, 08:35:02 PM
Reply #521
Mechanical Master
Reply #521 on:
June 12, 2016, 08:35:02 PM »
Hi Lars,
There is lots of discussion about prop rattle at low speed on Mercury's with certain props. My perception is that the gear ratio relative to pitch is the issue. In other words the prop tries to out run the gear ratio and over turns from interia into the gearset and causes a rattle condition. This is a common issue.
June 13, 2016, 12:59:16 AM
Reply #522
larsli68
Reply #522 on:
June 13, 2016, 12:59:16 AM »
You mean I would have this problem with a new prop as well?
I have read some forums now about the problem. Thanks for helping me understand it might not be a problem with the prop.
I will investigate if I have a III or IV hub.
Thanks,
Lars
June 14, 2016, 02:23:54 AM
Reply #523
larsli68
Reply #523 on:
June 14, 2016, 02:23:54 AM »
It turns out I have a flo torq II hub...
June 14, 2016, 06:03:10 AM
Reply #524
Mechanical Master
Reply #524 on:
June 14, 2016, 06:03:10 AM »
Hi Lars,
As you have discovered, this problem is not unique with stainless propellers on these engines. The aluminum propeller runs quiet at idle correct? It's also not unique to Mercurys either. My 60 Bigfoot Merc also does the same thing with stainless prop at idle. It has almost 800 hours on it so obviously the rattle hasn't hurt anything. What I had learn was it only had the rattle just in gear, so I got in the habit of bumping the throttle up to about 1000 rpm's in gear and the rattle goes away. I know this is annoying but you can get rid of it by changing driving habits when underway while driving at low speed.
36
37
45
