I am logged in, but no upload button. I have tried both Chrome and Firefox browsers.Do you have any ideas what to try next? I tried logging off and back on, but still no upload button.
I will double check tomorrow regarding the bend radii on the throttle cable and shifter. I have the cables and will test. Good point, thanks.The transom looks a bit spotty still, but I'm tickled to death over the result! It feels super strong already. I bet it will be the strongest transom in Sweden!I added two layers of fiberglass 600g/m2 on the inside of the hull of the stringers, before closing them up. I might still foam the stringers.The pipe bend I used is called a long bend. If I can't get the cables though, I will cut the inside radius and straighten it out with fiberglass. I will make it work.Thanks for bringing it to my attention.
