Author Topic: 1981 Aquasport 170 rebuild in Sweden  (Read 36319 times)
December 24, 2014, 09:37:41 AM
Reply #120
dburr
Re: 1981 Aquasport 170 rebuild in Sweden
« Reply #120 on: December 24, 2014, 09:37:41 AM »
Lars as bad as you've been bit by the bug, keep the Big Boss happy! She may let you think otherwise, but she is the CFO and Operations manager of the project and if you get out of square on your time management she may impose heavy penalties! :shock:  :oops:  :oops:  :mrgreen: !!
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
December 25, 2014, 04:18:27 AM
Reply #121
larsli68
« Reply #121 on: December 25, 2014, 04:18:27 AM »
Yes, you are both right. Rick, I probably jinxed it when I said May or June... Ain't mama happy ain't nobody happy. Today a Christmas day drive and enjoy the sunshine and the 1/4" of snow that fell last night.
No shoveling snow at least, and the boat is in a nice warm and dry shop! And I will be there tomorrow morning at 7AM!
December 26, 2014, 06:36:15 AM
Reply #122
larsli68
« Reply #122 on: December 26, 2014, 06:36:15 AM »
Finally Friday and 5 hours in the shop. Finished glassing the transom sides. Prepared the table with gel coat to be able to start with the floor tomorrow. I also prepared
a fiberglass strip to cover the tops of my stringers. I got quite a lot done today. Managed to take a couple of pictures too. Forgot to take a picture of the gelcoated table. Will do that tomorrow.
December 27, 2014, 11:02:12 AM
Reply #123
larsli68
« Reply #123 on: December 27, 2014, 11:02:12 AM »
Laminated the floor today. Also did some cleanup on the transom. Prepared the stringers for fiber glassing tomorrow.
A good day. Feels great to have the floor laminated! The Seacast pour will hopefully happen on Tuesday or Wednesday.
December 27, 2014, 11:51:09 AM
Reply #124
« Reply #124 on: December 27, 2014, 11:51:09 AM »
Nice job Lars.  :salut:  Real nice to have the tables and area to do this.
December 27, 2014, 11:56:27 PM
Reply #125
larsli68
« Reply #125 on: December 27, 2014, 11:56:27 PM »
It is unbelievable to get this opportunity. I'm very grateful. I'm also learning a lot from an retired guy that works extra at the place.
Stringers today and more... Getting the floor laminated yesterday felt really great.
December 29, 2014, 12:17:30 AM
Reply #126
larsli68
« Reply #126 on: December 29, 2014, 12:17:30 AM »
Glassed my stringers yesterday. It is 6:15 AM here and I'm preparing to go to "work" on the boat.
December 29, 2014, 04:45:53 AM
Reply #127
« Reply #127 on: December 29, 2014, 04:45:53 AM »
Are you going to foam the stringers?
December 29, 2014, 08:33:51 AM
Reply #128
larsli68
« Reply #128 on: December 29, 2014, 08:33:51 AM »
Quote from: "RickK"
I don't think so. They are now strengthen with 3 layers of 600g/m2 fiberglass. Do you think I have to?
They are strong and don't budge when I stand on them.
December 29, 2014, 09:43:33 AM
Reply #129
« Reply #129 on: December 29, 2014, 09:43:33 AM »
At this point it is more for flotation.  Are you planning filling the outsides of the stringers with foam (like it was originally)?  You said it was going to stay in the water, right?  Might be a good thing.   If it was going to live on a trailer and when out on the water you were in it, you knew it was safe and would not sink (of course unless you hit a submerged "something").
I foamed my stringers just in case.  And I am not planning on foaming the outsides of my stringers.  Boat is living on a trailer.  It took 1.5 gals of part A and B to do the stringers.
My $.02
December 29, 2014, 11:14:45 AM
Reply #130
« Reply #130 on: December 29, 2014, 11:14:45 AM »
You guys may consider doing what we did and lay block foam outside the stringers. Inexpensive, adds flotation, and deadens hull slap.
December 29, 2014, 11:49:25 AM
Reply #131
larsli68
« Reply #131 on: December 29, 2014, 11:49:25 AM »
Quote from: "RickK"
My $.02
I might foam the stringers, but the guy at the shop being my mentor thinks it's not necessary... I wouldn't mind but my boat will be in less than 2 feet of water at my dock.
I also plan to use two bilge pumps. One with a sensor always on and one that I can start with a button on my panel.
Today I glassed the underside of my hatch covers with that 600g/M2 fiberglass and added a 1/2 inch divinycell core to the laminate. I will finish them tomorrow.
I also plan to fix the new gas tank tomorrow, and hopefully do the Seacast tomorrow! It will be a long and exciting day!
December 29, 2014, 02:43:39 PM
Reply #132
« Reply #132 on: December 29, 2014, 02:43:39 PM »
Just more piece of mind than anything - If the stringers are stout you could probably get away without it since the foam does not add structure.
December 30, 2014, 08:37:29 AM
Reply #133
larsli68
« Reply #133 on: December 30, 2014, 08:37:29 AM »
Poured the transom today! It went really well.
I have to admit it feels like a million bucks to have this job behind me. Thanks to everyone in this forum that has given advice and support.
Thanks also to Jeff in Michigan who spent almost an hour on the phone with me giving great advice.
I also glassed the hatch covers, fitted a duct for the engine controls.
December 30, 2014, 09:19:11 AM
Reply #134
Georgie
« Reply #134 on: December 30, 2014, 09:19:11 AM »
Quote
 This is not true, Rick.  I don't typically like to make contradictory "call out" posts, and that's not my intent here, but this is a critical detail.  :|  While the trapezoidal stringers do have their own geometric strength, the foam inside is structural because it greatly reduces "compressibility" of the fiberglass and thereby helps them retain their shape and prevent buckling in the case of impact or a really bad wave.
This journal article briefly mentions the increased load capability for foam filled structures:  https://books.google.com/books?id=5YkMGtdsVuwC&pg=PA1017&lpg=PA1017&dq=hollow+vs+foam+filled+stringers+strength&source=bl&ots=Az2bm5P282&sig=EoYwmTDdSkYysvRLwEn-3Dc31kk&hl=en&sa=X&ei=g7GiVJ3AE4KvggT7oYPQDA&ved=0CB4Q6AEwAA#v=onepage&q=hollow%20vs%20foam%20filled%20stringers%20strength&f=false
Perhaps remember the surfboard analogy mentioned a couple years back on one or more rebuild threads?...or an alternative analogy - would you ever mount an engine to a two inch thick but hollow transom? (yes I know the forces being applied differ, but the priniciple is the same)
Lars, the foam in the stringers actually does not help with buoyancy unless the airlock within the stringer itself is breached and the boat is already taking on water, but it is assuredly critical to maximize the engineered strength of the build.   I strongly recommend you not skip this step. :salut:
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
