Author Topic: Awlgrip paint coverage  (Read 876 times)
October 10, 2014, 02:22:48 PM
Read 876 times
jwill3131
« on: October 10, 2014, 02:22:48 PM »
I have a 1975 246 ccc that I am getting ready to paint from the waterline up with awlgrip snow white topside. I am going to be using the roll and tip method and am having a hard time figuring out how much paint I am going to need for 2-3 coats. I've done some research on square footage but am getting slightly lost in the numbers. So I was wondering if anyone who has painted a 246 size boat could share how much paint they ended up using. From everything I've seen the 250 ccp is pretty close to the same size. I need to paint the inside too but I figure I'll have a good gauge for that after the outside is complete. Thanks.
Jason
February 06, 2015, 12:14:12 PM
Jack Hart
Re: Awlgrip paint coverage
« Reply #1 on: February 06, 2015, 12:14:12 PM »
If you roll and tip, you can expect that one gallon of paint combined with one gallon of catalyst mixed with the recommended thinner/solvent will give you about two coats on bottom and hull sides of a typical 24' boat.
October 16, 2015, 08:24:50 PM
jwill3131
« Reply #2 on: October 16, 2015, 08:24:50 PM »
So I'm thinking about spraying the awlgrip topcoat. Anyone with experience in spraying could you please let me know what type of spray gun I should use and nozzle size and all the other info I might need to know before going this route. Thanks
December 22, 2015, 03:22:21 PM
Shine
« Reply #3 on: December 22, 2015, 03:22:21 PM »
For a boat that size, you will use 2-3 quarts of color.  Your probably better off buying a gallon for the price.
January 11, 2016, 12:32:30 PM
jwill3131
« Reply #4 on: January 11, 2016, 12:32:30 PM »
Thank you for the response. I already have a gallon of the snow white with the brushing converter and reducer but I was thinking that it would be easier to spray the inside and everything else(console, T-top, outboard bracket). Now I know I'll have enough to roll and tip the outside and what I need for the other. Thanks again.
