Author Topic: 1970 222 flatback stringer height  (Read 3386 times)
September 23, 2014, 09:05:51 PM
Read 3386 times
Rogojax
  • FL - South Area
« on: September 23, 2014, 09:05:51 PM »
Stringer height
September 23, 2014, 09:59:05 PM
Re: 1970 222 flatback stringer height
« Reply #1 on: September 23, 2014, 09:59:05 PM »
Some members have raised the deck as much as 6 inches higher than factory.
Others went 2 inches.
Now that we have separate rebuild threads for many models....will recommend that you go to the Flatback section and research. If you're closing the transom as most Tampa-style rebuilds, you'll probably want to go a bit higher, since they usually run 175's,  200's etc. on jackplates.
Open transom, different story.
The current flatback rebuilders have gleaned much from their predecessors. Will leave it to them for specific advice.
Welcome aboard!
September 23, 2014, 10:06:31 PM
« Reply #2 on: September 23, 2014, 10:06:31 PM »
Please post pics of your flatback. And tell us where you're from.
May 30, 2015, 07:43:53 PM
Rogojax
  • FL - South Area
Re: 1970 222 flatback rebuild
« Reply #3 on: May 30, 2015, 07:43:53 PM »
Well finally started the flat back I am from north ft Myers fl good friend of mine is rebuilding it in Punta gorda here are some photos when we first got the boat
May 30, 2015, 07:45:25 PM
Rogojax
  • FL - South Area
« Reply #4 on: May 30, 2015, 07:45:25 PM »
Transom complete
May 30, 2015, 07:48:38 PM
Rogojax
  • FL - South Area
« Reply #5 on: May 30, 2015, 07:48:38 PM »
Got the windows glassed and started mocking up the stringers
May 30, 2015, 08:10:55 PM
« Reply #6 on: May 30, 2015, 08:10:55 PM »
Transom complete
Nice work!
You removed the windows? Seems a lot of owners do, not sure why.  Maybe the rearranging of compartments?
I piloted a windowed FB once and thought it was pretty cool to actually "see" the bottom I was over.
They seem to be a scarce item anymore.
May 30, 2015, 08:11:59 PM
Rogojax
  • FL - South Area
« Reply #7 on: May 30, 2015, 08:11:59 PM »
Thank you sir
May 30, 2015, 08:12:52 PM
Rogojax
  • FL - South Area
« Reply #8 on: May 30, 2015, 08:12:52 PM »
I am trying to post a bunch of new pictures but it keeps saying each picture is to big?
May 30, 2015, 08:25:38 PM
Rogojax
  • FL - South Area
« Reply #9 on: May 30, 2015, 08:25:38 PM »
Yea I didn't want to ever half to worry about them leaking but that would be pretty cool
May 30, 2015, 08:27:59 PM
« Reply #10 on: May 30, 2015, 08:27:59 PM »
Don't "attach" them (pictures), follow the instructions here http://classicaquasport.com/smf/index.php?topic=12725.0
The gallery will resize them to what we need automatically and then posting the IMG code is what you want to copy/paste into your post.  You can open multiple browser tabs to make it easier.
Let me know if you need more help - read the link closely (or a few times) and you should be good.
It's very simple.
May 30, 2015, 08:37:20 PM
« Reply #11 on: May 30, 2015, 08:37:20 PM »
They were placed in a live well
I'm not sure if they leaked, what would happen other than fill up the livewell more? If I remember right, the livewells didn't have an overflow pipe or way to evacuate extra water.
January 03, 2016, 03:46:44 PM
Rogojax
  • FL - South Area
« Reply #12 on: January 03, 2016, 03:46:44 PM »
January 03, 2016, 03:53:28 PM
Rogojax
  • FL - South Area
« Reply #13 on: January 03, 2016, 03:53:28 PM »
1970 222 beginning
January 03, 2016, 05:55:18 PM
« Reply #14 on: January 03, 2016, 05:55:18 PM »
Is this an "After and before" set of pics?  The seafoam one looks great.
