Engines & engine woes
Navigation structure/engine weight 170 90hp
Topic: Navigation structure/engine weight 170 90hp (Read 389 times)
September 02, 2014, 09:47:30 AM
Read 389 times
nightrain76
September 02, 2014, 09:47:30 AM »
Hi, I write from Italy, I have a problem with the navigation structure of my aquasport 17 feet, I mounted a motor 90 hp johnson ocean runner, do you think is too heavy for this type of boat? Thanks
September 02, 2014, 10:21:06 AM
Re: Navigation structure
September 02, 2014, 10:21:06 AM »
Not sure what you mean by navigation structure? But a 90 should be fine on a 17.
2003 Osprey 225
September 02, 2014, 10:33:40 AM
nightrain76
September 02, 2014, 10:33:40 AM »
it's not too heavy for the back of the boat?
September 02, 2014, 10:47:54 AM
Global Moderator
September 02, 2014, 10:47:54 AM »
Quote from: "nightrain76"
Well it is lighter than the 115 hp you use to have back there.
As stated above, the 90 hp is a great hp to weight ratio motor.
Might not be as fast WOT as your old 115 but should ride and handle very well.
Perfect size for your hull.
September 02, 2014, 11:20:53 AM
September 02, 2014, 11:20:53 AM »
I assume your talking about a two stroke 90HP and not a four stroke.
I have a 90hp Ocean Pro on the back of my 170 and it is plenty of power.
