Any idea what was behind or in place of this aluminum plate?
Good evening to everyone. I will say hello and first round of drinks are on me! I just picked up a 92 175 with a 150 black max for a pretty good price. I have alot of work to do to her, I already replaced axle and running gear on trailer. The lower unit was pulled due to hard shifting. Water was the culprit, so I have a rebuilt unit from SternDrive that I will pick up maybe Tuesday. I have alot of screw holes to fill. I am familiar with Gelcoat. My question is there are several holes in the transom that I want to fill. I would like to inject a little bit of resin and finish with gel. Is this the correct repair? Same with several in the deck. Is the transom wood or poured on this model? Inside the screw holes it seems pretty hard. Anyways thanks in advance, and I am working on some pics.
heres mine. got her put together enough to take on a river run tomorrow to try out the new additions. this is my leaning post that I put in (today actually). I got it from S&E customs on ebay, it came 32" tall which was too tall. I had it cut down 2" and its about perfect IMO but tomorrow will be the maiden voyage and a good test. I think it really depends what you like to do more, rough water and standing up/leaning more, or just cruising and sitting more. mine came with the backrest and is really pretty comfortable to sit on with youre feet on the flip out footrest or to prop up against while standing.PS- mine runs about 37mph by the GPS with my 88spl that im sure isn't still at its rated HP level. so with a 150 I bet itd be pretty wicked. I was thinking about going up to a 135 to really help with the holeshot and gain some topend
thanx. just got back from our river ride. leaning post IMO was about perfect height, MAYBE 1/2" lower would've been nice. with the footrest down it was nice to sit on and I could easily drive and with the rest up I could prop and drive comfortably. I think 28" would be nice for a primarily sitting type stand but would be too low to prop up against comfortably. also the backrest was a VERY nice addition for when I was sitting.
