Trailers
Can anyone identify this appendage?
Topic: Can anyone identify this appendage? (Read 607 times)
August 11, 2014, 02:00:06 AM
Read 607 times
Woodeneye
August 11, 2014, 02:00:06 AM »
.....and what its for?? Its a Gator Trailer....I think....
August 11, 2014, 06:26:21 AM
dburr
Re: Can anyone identify this appendage?
August 11, 2014, 06:26:21 AM »
I have seen something similar to that once before and it is a jack, (yours seems to be missing the handle) the allows you to adjust the angle of the trailer frame in relation to the tongue. On a flat ramp you can crank the jack up and this will aid in sliding the boat off the trailer. Reverse the procedure and it will keep the boat from coming up hard over the end bunks or rollers at too step an angle then crashing down the trailer. Great idea for beach launchings and areas with flat ramps....
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
August 14, 2014, 12:59:00 AM
Woodeneye
August 14, 2014, 12:59:00 AM »
Thats kinda what I figured but there just doesn't seem to be enough travel or adjustment in it for it to accomplish what you and I thought.
August 14, 2014, 10:13:32 AM
August 14, 2014, 10:13:32 AM »
this is a tilt trailer?? I would say it is a bracing arm for the tilt portion of the trailer to keep it in a tilted position, it looks like there is a clevis like device above it that at one time would recieve that piece and you could put a pin or bolt through the journal. why you would want to keep it tilted??
August 14, 2014, 04:49:33 PM
August 14, 2014, 04:49:33 PM »
Interesting. Yup it is a jack that has had a bracket welded onto the body of it to allow you to tilt and un-tilt the trailer. Much safer than just a pin that just lets the thing swing up. As already mentioned the handle is MIA.
August 14, 2014, 06:01:01 PM
August 14, 2014, 06:01:01 PM »
That would be a good way to keep water out of your boat at the house instead of trying to jack it way up :!:
August 14, 2014, 11:10:00 PM
Global Moderator
August 14, 2014, 11:10:00 PM »
Kinda reminds me of me.............
In my youth.
Trailers
