Author Topic: What sized hole should I drill?  (Read 611 times)
August 10, 2014, 10:20:26 PM
Read 611 times
« on: August 10, 2014, 10:20:26 PM »
So you have to fasten something to anything with a machine screw or a wood screw.... but what sized hole should you drill? We all have various tools to do every little thing but how many of us use a drill gauge? Drilling the correct sized hole can make all the difference between a professional installation and a regret.
A must have in my opinion is a 29 bit drill index and a matching drill gauge. The holes in the gauge correspond to the drill sizes in the index (except for maybe the larger holes in the index). I believe they both go up by 1/64th of an inch.  This one is a cobalt drill set from Sears Craftsman and will run you about $120. You need cobalt to drill stainless. As I break drill bits I replace them with individually bought ones to keep my set complete. If you never intend on drilling stainless you can get a similar drill index for less than half of that.
The drill gauge is an old school heavy steel one my father had laying around. It doesn't show well in the photo, but the drill gauge has the fractional size of the hole stamped next to the hole. This is the size of the drill bit to use to make that hole.  Do not by a plastic one as it will not hold up.
Lets say you have selected the appropriate machine screw to install an item. You then pass that screw through a hole that fits on the gauge to see what size drill to use. If you want a tighter hole you would use the first smallest size that fits. If you want it a little looser you would go a size up.
Let say you want to mount a wood screw. In this example the screw fits a 1/4 inch hole.
 But a wood screw has to go into a smaller hole in order for the threads to hold. So you try a few holes smaller and pick the one where you cannot get the screw to thread into, in this case 13/64ths. In fact you can even go one size smaller at times and if the screw is hard going in you can then drill it again with the next size up drill bit.
In this example if you drilled a 1/4 inch hole you would be screwed as there would be nothing for the threads to hold to. However, sometimes this is what you want to happen. For example if you wanted to screw a piece of teak to something with a wood screw. You may not want the threads to grab the piece of teak, rather you want the screw to grab to the thing you are screwing the teak into. You would line the teak piece up to where its being mounted, drill a 13/64th hole through both items, then remove the teak and drill a 1/4 in hole in just the teak. When you install the screw it will pull the teak hard against the mounting surface for a great hold.
My set fits together nicely so I always have them together.
In this photo I am using a automatic center punch to create a dimple for the drill bit to start in. As you depress the punch, it is spring loaded and will hammer a dimple in anything including steel.
I then use a small drill bit to drill the first hole as a small drill bit will be less likely to try to walk out of the dimple. I then follow it up with the correct sized bit which is lying on the table.
 This process takes the guesswork out of which drill bit to use for which screw and leaves you with professional results and peace of mind. My drill, bits, gauge and center punch all fit nicely in the tool bag that came with my drill. Drilling holes may seem simple but this method makes it foolproof to get it done correctly.
August 11, 2014, 12:21:13 AM
Georgie
Re: What sized hole should I drill?
« Reply #1 on: August 11, 2014, 12:21:13 AM »
Steve - can't even begin to tell you how valuable your photo-documentation has been for your followers, and now you're branching into "intentional tutorials" versus just "project documentation".  :cheers:  You're a capital member here!
If I may add a few things for further consideration/elaboration/discussion...
1-"clearance" holes accommodate the full diameter of the fastener and its threads so that there is no "bite" or "pull", while "tapping" holes only provide room for the shank of the screw and leave sufficient material for the threads to "bite" into.
2-It's important to recognize that the size of the tapping hole drilled for bedding in hard brittle materials (like gelcoat or concrete) is different (larger) from the size of the hole drilled to bed softer and more compressible material like fiberglass or wood (smaller).
3-drilling pilot holes with small bits can at times make the secondary drill wobble or otherwise cut the material improperly.  I personally have found that the pilot hole in these instances should ONLY be drilled deep enough to keep the final/secondary bit from wandering.
I know there are more pointers floating in my head somewhere, but given the time and the rum  :drunken: , they are apparently in witness protection.   8)
Thank you for taking the time you do to pass on your wealth of knowledge and experience.   :salut:
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
August 11, 2014, 12:26:58 AM
« Reply #2 on: August 11, 2014, 12:26:58 AM »
Thank you for the kind words and great information Ryan I appreciate it. I agree with the idea of just starting the hole with the small bit, then allowing the larger bit to fully cut it's own path. Makes sense to me.
 Anyone else please feel free to share your experiences. Drilling holes is so important yet so taken for granted.
August 11, 2014, 07:13:01 AM
dburr
« Reply #3 on: August 11, 2014, 07:13:01 AM »
Outstanding Steve and Ryan!!
A little more follow up from the school of hard knocks and broken bits
A common mistake is that we grab a drill and the drill motor, chuck up a drill, line her up and pull the trigger and push hard because we think we need to. The hole starts to go then we push harder until snap, we are then surprised and the cussing begins…
The key missing components are a sharp drill, correct drill speed and cutting lubricant.
Some folks may want to quibble about the use of cutting oil, we are not working for NASA so the bottom line is use something to keep the drill bit lubed, mayonnaise, WD40 or the real deal cutting oil. Just understand that with a dull bit and a low flash point on the cutting fluid you stand a chance of losing your eyebrows once you start to see smoke. The less flammable stuff you use the better off you are..
To get the right speed a little math is involved unless you have a table handy.  The old school machining formula is 4*CS/D, with CS being the cutting speed of the material and D the diameter of the either the material (when cutting on a lathe) or the bit.  Keeping track of the units is a bit of a bother because most speeds are in feet per minute and the drills we use are in fractional inches..
To make it even easier, from the info that Irwin provides: RPM = SFM x 3.82/Drill Diameter
Excerpt from the Irwin attachment:
Speeds for High Speed Steel Drills    SFM*
Aluminum and its Alloys       200-300
Brass and Bronze (Ordinary)      150-300
Bronze (High Tensile)                 70-150
Die Castings (Zinc Base)       300-400
Iron-Cast (Soft)          100-150
Magnesium and its Alloys       250-400
Steel - Mild (.2 carbon to .3 carbon)    80-110
Forgings            40-50
Stainless Steel
Free Machining Grades       30-80
Work Hardening Grades       15-50
Attachment is from the Irwin website
[attachment=0:39tqbrwf]Drill guide.pdf[/attachment:39tqbrwf]
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
August 11, 2014, 09:56:20 AM
« Reply #4 on: August 11, 2014, 09:56:20 AM »
That drill guide is awesome. Thanks for sharing.
