Author Topic: 205 Osprey w/Johnson 200 - what's your prop?  (Read 748 times)
August 10, 2014, 01:12:24 PM
Read 748 times
CMG241
« on: August 10, 2014, 01:12:24 PM »
Hi all, I am under prop'd with a 14.5x19 three blade. New to me 1998 boat and from what I find on line searching is that I should't go beyond 6,000 revs. I could (had not/would not) probably pass 7k as is with four passengers & full tank of fuel. SUGGESTIONS PLEASE!!
Thanks much (I did search first and found nothing)
Chris G
1998 Aquasport 205
August 10, 2014, 06:39:10 PM
Re: 205 Osprey w/Johnson 200 - what's your prop?
« Reply #1 on: August 10, 2014, 06:39:10 PM »
Same hull config as yours but in a longer length
viewtopic.php?p=50415#p50415
This hull is also similar to yours.
viewtopic.php?p=38451#p38451
Use these as starting points in your search. The Prop forum also has several links to tutorials on the black art of proper propping.
Hopefully someone else will chime in.
October 06, 2014, 05:40:06 PM
CMG241
« Reply #2 on: October 06, 2014, 05:40:06 PM »
fixed,kind of.. tach niot the prop. tap tap on glass and it dropped 1k revs
Chris G
1998 Aquasport 205
