Hello All: I should be purchasing my 222 in the next week or two and will be starting my rebuild shortly there after. I had some questions of the experts (you all) and wanted your input as I start to formulate a plan for the boat. I am primarily going to use the boat in Fort Pierce Fl and in the keys. It will be used for spearing fish (free diving) and fishing. It needs to be easily trailerable. I am planning on new stringers, floor, transom console, motor, wiring, etc. I plan on enclosing the transom. The questions are as follows:1- Should I raise the floor and if so how much? What determines how much? 2-I would like to have a livewell, should I add one to the transom or an oval style one to double as a leaning post?3- On my Sea Vee and other boats I have owned, I like having a bracket on the transom to mount the motor, is this a good idea with the 222 or should I use a adjustable "jack plate" type system and have platforms on either side of it?4- What is the normal size of the fuel tank in a 222? can I put a 100 gallon tank in it? 5- I am thinking of using a Yamaha 200 4 cyl 4 stroke, any down sides? Is that an adequate size motor? I like to have the availability to go fast but would probably cruise much slower6-Where would the most economical place to buy resin, cloth, stringer materials, floor materials, etc. be in this area? Can run to Palm Beach or further if needed?I will have a lot more questions soon but I appreciate the help.Ed
