Author Topic: Sudden no power to motor or tilt/trim - Help diagnose  (Read 3598 times)
July 31, 2014, 05:42:17 PM
cphilip
Re: Sudden no power to motor or tilt/trim - Help diagnose
« Reply #15 on: July 31, 2014, 05:42:17 PM »
I'd be tempted to pull a new one if one could be found. I just wish I could wiggle the right place while I had a helper and it change something. So far I've had no luck finding the location. Wiggled a lot of them.
So far it still cranks over and still tilts. Rained out today though.
97 165 Striper w/ Suzuki DT65
Clemson, South Carolina
July 31, 2014, 07:08:17 PM
gman 82 aquasport
« Reply #16 on: July 31, 2014, 07:08:17 PM »
Thats the bad part of wiring issues, they never mess up when you want them to, it's always when it's going to be a pain :pale:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
August 01, 2014, 11:08:53 AM
cphilip
« Reply #17 on: August 01, 2014, 11:08:53 AM »
New plugs didn't solve the no start issue so I am going to have to go in there and look. That means the console has to come lose so I can see. I imagine (and hope) I'm going to find a plug partly dislodged or wire pulled lose from one right under there where it all comes together. I can see it all there, just can't reach it nor get my head in far enough to see things real good. Luckily it appears its four screws on each side and I can lay it over, leaving everything intact and get to the area really well then. Just have to break the bond of existing sealant and replace when done. And then hopefully it will be obvious with some careful examination. I guess I'll start on that in the morning. I want to do one more thing before I do that. I want to visually verify I have no spark at the motor. I have to have help for that. But I want to verify that for certain.
My fear of dislodging something when installing that Lowrance has come true. No way to really have prevented it I guess. Still can't understand what went wrong and why my step by step verification of functions lied to me. But... it is what it is I guess. Temped to pay someone to deal with it! Just don't know if there is anyone trustworthy in the area really.
Curse you Lowrance and your big ass plugs!!!!  :evil:
August 14, 2014, 01:51:07 PM
cphilip
« Reply #18 on: August 14, 2014, 01:51:07 PM »
Ok... having employed a more nimble person to help.... we found a cracked plug that also had one broken pin within it. Probably had some non contact wires as well but replacing that set with new fixed the power problems as far as we can tell this point. It may have been one I hit with the transducer plug I would expect. The intermittent Bilge pump that occurred was a complete red herring. It was unrelated but could be related to when I put the plug through the boot back at the rear and just went unnoticed until diagnosing the other problems. At this point I think its all fixed. New plugs and some new butt connections.
I think the best thing to do now is invest in a US Tow account just for insurance. And hit the lake.
