Aquasport Discussion
Cooler size for 170?
Topic: Cooler size for 170? (Read 560 times)
July 19, 2014, 04:59:11 PM
Read 560 times
Slo Poke 1
July 19, 2014, 04:59:11 PM »
What is the largest cooler that will fit between the CC and front deck in the 17-footer?
July 19, 2014, 07:41:20 PM
Re: Cooler size for 170?
July 19, 2014, 07:41:20 PM »
First question is what year 170.
Mine didn't have a seat or a livewell in the front. It was all console so I put a cooler as a seat in front of the console.
I think I had a 60gal as a seat there in front of the console. I still have it out in the yard but I don't think there are markings left that you can read.
July 19, 2014, 08:18:26 PM
Purgatory
July 19, 2014, 08:18:26 PM »
If you want big, Igloo makes a 128 that is only 18.75 inches wide, 42 inches long. Will make a good fishbox, etc.
July 19, 2014, 08:23:58 PM
July 19, 2014, 08:23:58 PM »
I think the console is only 30" wide so that won't work.
July 19, 2014, 08:30:28 PM
Slo Poke 1
July 19, 2014, 08:30:28 PM »
Not really any specific year, but boats with a bench seat in front if the console. I was leaning towards a 196, but the 17 might be big enough to suit our needs. I have an 80 quart Rubbermaid, but I'm certainly not going to buy a boat based on an existing cooler if other decent size coolers would fit there.
July 19, 2014, 09:29:48 PM
Purgatory
July 19, 2014, 09:29:48 PM »
Quote from: "RickK"
It'll work. May have to step around it, but he said "largest"
July 20, 2014, 10:18:09 AM
Slo Poke 1
July 20, 2014, 10:18:09 AM »
What's the distance from the bench to the front deck.
July 20, 2014, 06:48:22 PM
July 20, 2014, 06:48:22 PM »
On a 170/175 that has a seat/livewell attached to the front of the console, there should be about enough room in front of the seat to set a cooler. Remember that hull starts it's taper about right there so it gets narrower as you move forward. Might be best to figure the cooler behind the helm seat/cooler.
July 20, 2014, 07:52:41 PM
Slo Poke 1
July 20, 2014, 07:52:41 PM »
Thanks all.
