Fiberglass and Materials Corner
resin peanut butter question
Topic: resin peanut butter question (Read 594 times)
July 14, 2014, 06:49:56 PM
Read 594 times
aquamod939
July 14, 2014, 06:49:56 PM »
I have one gallon of epoxy and was wondering if I can use the epoxy to make my peanut butter and use poly for everything else?
July 14, 2014, 06:56:07 PM
Re: resin peanut butter question
July 14, 2014, 06:56:07 PM »
Remember that poly will not stick to epoxy so you have to be very methodical on the use of both and the delineation between them.
July 14, 2014, 07:00:20 PM
July 14, 2014, 07:00:20 PM »
You can certainly mix the epoxy with cabosil or other additives to make a peanut butter consistency. And you can certainly use poly. But you can't use the poly over the epoxy, as it won't stick very well.
edit: you beat me to it, Rick
