Author Topic: Mount stern cleats, w/hawse pipes, w/out nuts on outside??  (Read 3379 times)
June 24, 2014, 09:44:03 AM
Re: Mount stern cleats, w/hawse pipes, w/out nuts on outside
« Reply #15 on: June 24, 2014, 09:44:03 AM »
That could look nice, Ryan.  You'd definitely want to use some loctite on those threads, though...
June 24, 2014, 09:49:44 AM
« Reply #16 on: June 24, 2014, 09:49:44 AM »
What if you just used carriage bolts and run them from the outside in? Another option is a barrel nut. It's basically a short threaded tube with a screw head on the end. The threaded tube part would recess into the transom leaving the only the screw head on the outside.
http://www.jamestowndistributors.com/us ... o?pid=1451
June 24, 2014, 10:09:17 AM
« Reply #17 on: June 24, 2014, 10:09:17 AM »
I Like that barrel nut. That's really clean looking. I didn't know they existed.
June 24, 2014, 10:22:01 AM
« Reply #18 on: June 24, 2014, 10:22:01 AM »
Well Ryan certainly has some options to mull over.  I like the barrel nut too...excellent find, Bruce!! :salut:  :salut:
June 24, 2014, 10:40:05 AM
Georgie
« Reply #19 on: June 24, 2014, 10:40:05 AM »
X2 on the barrel nut!   :thumleft:  Deluxe solution!!
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
June 24, 2014, 10:45:12 AM
SaltH2OHokie
  • Mid Atlantic
« Reply #20 on: June 24, 2014, 10:45:12 AM »
Yeah, holy cow...thank y'all for the brainstorming session!  :thumright:
Of the various thoughts, I'm also liking the "barrel nut" because it strikes a good balance between smooth transom and work required...Ironically, we use them all the time at work, only with a smooth head and the portion of the shaft just below the head is splined, rather than #2 Philips shown above.  Just never would have translated their use over to the boat without Bruce.
For the record, we call them sex bolts.  No idea if that's improper...but that's all I've ever heard them called.  Use them on commercial door hardware, some casework applications, etc.
Thanks again!  Going to order a few 1/4-20 and give it a go.
Ryan
June 24, 2014, 11:24:14 AM
« Reply #21 on: June 24, 2014, 11:24:14 AM »
Lots of good ideas here.  If you can find the sex bolts (gotta admit, that sounds better than barrel nuts) in 316, that would be the ticket.  18-8 is more like 304, and not as corrosion resistant as 316.  Worst case, order extras and swap them out if they start to rust.
June 24, 2014, 11:30:09 AM
« Reply #22 on: June 24, 2014, 11:30:09 AM »
The challenge i see with the barrel nuts over the tee nuts is screw length will be critical. With the tee nut you can crank it down and cut off the excess.  Can't do that with the barrel nut although I definitely like the look of the Phillips barrel nut over the tee nut.
June 24, 2014, 11:50:48 AM
« Reply #23 on: June 24, 2014, 11:50:48 AM »
I've used barrel nuts on other projects and they work great.  I just posted that link simply because it was the first one that came up on a search.  I'm sure McMaster or Fastenal has other choices.  I think a sex bolt is different since it is intended to locked into the substrate and not be turned.  I have seen the barrel nuts with flathead, torx or hex drives.
June 24, 2014, 12:42:42 PM
« Reply #24 on: June 24, 2014, 12:42:42 PM »
Knew ten heads were better than one! Good thinking fellas :thumright:
June 24, 2014, 12:46:20 PM
« Reply #25 on: June 24, 2014, 12:46:20 PM »
A lot of smart folks here, Scotty... :thumleft:  :thumleft:
June 24, 2014, 01:00:51 PM
« Reply #26 on: June 24, 2014, 01:00:51 PM »
Definitely don't forget the lock-tite. I'm sure they will get loose over time without it. (Of course, you probably already thought of that tho   :wink: )
June 24, 2014, 01:56:02 PM
SaltH2OHokie
  • Mid Atlantic
« Reply #27 on: June 24, 2014, 01:56:02 PM »
Quote from: "RickK"
Naw, I don't need Loctite.  As long as I tell myself "you have to be able to loosen that bolt in the future" as I'm tightening it, I positively will gall the threads beyond ever loosening again.
Conversely, if I squirt mil-spec, super-duty, red Loctite all over it, not only will it not gall, but it will back itself out when I least want it to.   :lol:
Ryan
June 24, 2014, 01:58:34 PM
SaltH2OHokie
  • Mid Atlantic
« Reply #28 on: June 24, 2014, 01:58:34 PM »
I want to add: Thanks again for all of the replies, but the more I think about it...if I get to watch my wife fall into the water every few days, and laugh on the inside, I might just tell her that I'm still thinking about how to mount cleats in the stern  :twisted:
Ryan
June 24, 2014, 02:23:19 PM
« Reply #29 on: June 24, 2014, 02:23:19 PM »
You're a sick man Ryan  :mrgreen:
