Author Topic: 200 trim tab placement  (Read 665 times)
June 20, 2014, 10:33:49 AM
Read 665 times
redemn93
« on: June 20, 2014, 10:33:49 AM »
hey guys.  i have a set of 8 or 9"x12" tabs with lenco rams to install in the next few weeks.  where on the transom, in or out, should i mount the tabs?  anybody have any pics?  i understand where to mount height wise but not sure where to go in or out on the transom.  kinda need to know by tomorrow morning so i can mount my transducer without fear of being in the way of the tabs later.  thanks.
Jason.  1987 200 Osprey - almost done...for now
June 20, 2014, 11:35:22 AM
ktisdall
  • NorthEast
Re: 200 trim tab placement
« Reply #1 on: June 20, 2014, 11:35:22 AM »
I know with bennetts they want them placed out to the sides as far as possible given the chine shape.
On my ccp200 they are just in from the sides starting where the flat chine meets the "V" part of the hull.
--Kevin
June 20, 2014, 11:44:14 AM
redemn93
« Reply #2 on: June 20, 2014, 11:44:14 AM »
yeah kinda what i figured.  thats the popular method.  i just need to hold them up and make sure i mount the ducer out of the way.
June 20, 2014, 11:47:00 AM
« Reply #3 on: June 20, 2014, 11:47:00 AM »
Quote from: "ktisdall"
--Kevin
This...
Ya wannna pic?
June 20, 2014, 11:50:20 AM
redemn93
« Reply #4 on: June 20, 2014, 11:50:20 AM »
why not?
and how do you like to mount your garmin ducers bob?  mid-line of the ducer even with the bottom?
June 20, 2014, 12:16:08 PM
« Reply #5 on: June 20, 2014, 12:16:08 PM »
The ideal location, given a hull bottom with a pronounced chine, either flat or reverse.  Obviously, these are Bennetts, but same principal applies to Lencos.  The outboard edge of the plane right at the radius where the chines meets the hull bottom, between 1/4" and 3/16" above the hull bottom...
As far as Garmin, or anyone elses transducer, basically what you said, Jason.  Here's a Garmin on Wes Napp's 200 Osprey...
The pic doesn't show it. but the inboard edge is 1/8" above the hull bottom.  This position works VERY well for holding bottom at speed...
June 20, 2014, 12:22:02 PM
redemn93
« Reply #6 on: June 20, 2014, 12:22:02 PM »
awesome.  thanks bob.
June 20, 2014, 12:28:57 PM
« Reply #7 on: June 20, 2014, 12:28:57 PM »
My pleasure, Jason.  On Wes's 200, I would have preferred to move the ducer a bit further away from the tab, but just adjacent to the UW light you see there, he has a transom mount TM, so it had to stay in that location.  Whoever installed it for him basically didn't know what they were doing...imagine that...
June 20, 2014, 12:43:08 PM
redemn93
« Reply #8 on: June 20, 2014, 12:43:08 PM »
understood.  ill keep that in mind.  thanks.
June 20, 2014, 05:49:07 PM
« Reply #9 on: June 20, 2014, 05:49:07 PM »
heres where i installed my 12x9 bennett tabs on the boat before i did any work to it...
June 20, 2014, 06:53:28 PM
redemn93
« Reply #10 on: June 20, 2014, 06:53:28 PM »
thanks aaron.
