Author Topic: Divincicell PVC 5lb foam board  (Read 1176 times)
June 18, 2014, 06:35:43 PM
Re: Divincicell PVC 5lb foam board
« Reply #15 on: June 18, 2014, 06:35:43 PM »
Divinycell will not hold a screw at all! I used it for my coffin cover and had to over drill all the holes and fill with thickened epoxy. If not done this way the only grip for the screws will be in the skin. I lammed one layer of mat onto the skin just to even it up and then bedded the foam into the epoxy. Last layer was one wet out piece of 1708. Even today after two years no issues. The whole thing now acts like a diving board with just a little flex. If you are bridging a wider area I would highly recommend 2 layers of 1708 on the bottom for more stiffness.
Plywood weighs around 40 lbs per cubic foot. Obviously the Divinycell you are looking at weighs 5 per cubic foot. Coosa 26 weighs 26 and so forth. Quite a weight savings on a large area! Good luck!
June 19, 2014, 03:46:01 PM
florida196
« Reply #16 on: June 19, 2014, 03:46:01 PM »
Alright so left work early today cause I really didn't want to miss out on this composite board deal.   This stuff is crazy light compared to marine plywood.  Almost scares me thinking it won't be strong enough but gunna run two layers of 1708 on bottoms and same on top side so should be good here is what it looks like incase anyone was woundering
June 19, 2014, 04:00:05 PM
« Reply #17 on: June 19, 2014, 04:00:05 PM »
That's it all right. It will be like walking on rock when you're through :salut:
June 19, 2014, 05:08:07 PM
florida196
« Reply #18 on: June 19, 2014, 05:08:07 PM »
That's good to know this stuff has got me pretty excited ready to get the work
