Author Topic: NMEA0183 questions  (Read 938 times)
June 05, 2014, 10:33:05 AM
Read 938 times
xo4001
NMEA0183 questions
« on: June 05, 2014, 10:33:05 AM »
This is probably a question for Bob
Recently installed a old radar Koden MDC741 and its working good
Found that it can accept NMEA input also my VHF can accept this
My question is can I buy a GPS puck with this output and connect both on this puck or do I need some kind of a splitter
My chart plotter fish finder raymarine dragon fly has no NMEA output so the only solution I see is to buy a puck
Other question is can I short the cable between the Radar dome and display because it's far to long but dont know if this has any effect on the working of the unit
Any input is welcome
Thanks in advance
1971? Aquasport 240 Seahunter
H254
2 X Merc 115 4s
June 05, 2014, 11:10:17 AM
SaltH2OHokie
  • Mid Atlantic
Re: NMEA0183 questions
« Reply #1 on: June 05, 2014, 11:10:17 AM »
I bought a Garmin puck that fed 3 0183 devices with no splitter...
Can't help with radar cord.
Ryan
1975 Aquasport 19-6, 1985 Merc 115 Inline.
1970 Aquasport 22-2, 1987(ish) Yamaha 115 V4.
Former owner of 1988 Aquasport 290 TM.
Currently on nothing but cell phone/air card.  Which severely limits internet time.
June 05, 2014, 12:55:18 PM
« Reply #2 on: June 05, 2014, 12:55:18 PM »
OK....some MFDs/Radars/VHFs will work with any GPS antenna...some won't.  Lowrance and Raymarine being the 2 most noted.  That being said, I would contact Koden, but it looks like it's gonna have to be an email, as their contact page only lists facilities in Japan...http://www.koden-electronics.co.jp/eng/ ... index.html
Now the radar cable.  I cannot say for certain in regards to Koden, but I CAN say for certain in regards to Raytheon/Raymarine and Furuno.  On magnetron type radars (versus today's digital radars), the cable length is specified when ordered, and the radome is "calibrated" to that length of cable.  If the cable is shortened, the radome must be re-calibrated by an authorized factory tech.  Today's digital radars, which simply use an ethernet cable to transmit data, any length can be used.  Once again, an email to Koden is in order...
June 05, 2014, 03:12:51 PM
SaltH2OHokie
  • Mid Atlantic
« Reply #3 on: June 05, 2014, 03:12:51 PM »
Now shouldn't NMEA 0183 compliant mean NMEA 0183 compliant, regardless of brand Bob?
Ryan
June 05, 2014, 03:28:00 PM
« Reply #4 on: June 05, 2014, 03:28:00 PM »
Quote from: "SaltH2OHokie"
That's correct Ryan...in the concept of what data can be communicated between units...the "sentences", so to speak.  But GPS is GPS, regardless of what communication proticol is being used.  It's how the unit receives the LAT/LON from the puck that is the issue.  Once a head unit achieves a fix, then the 0183 coding takes over to transmit that data to other 0183-capable devices, most notably, VHF radios for DSC functionality.  But the head unit first has to be able to receive and use that GPS signal...which has nothing to do with 0183, 2000, or whatever...
June 05, 2014, 03:33:12 PM
« Reply #5 on: June 05, 2014, 03:33:12 PM »
Ryan, the best "for instance" is Raymarine.  Their head units must use a Raystar 125 or 130, they will not recognize a Garmin, Lowrance, H-B, or anyone else's antenna.  This ensures you buy their antenna, and if you've ever priced used Raystar's on ebay, well, there's a reason they are up there, as opposed to a used Garmin GPS 17, for instance.
Of course, as I said above, once the fix has been achieved, then 0183 takes over in regards to distributing data to whatever NMEA device, made by whomever, you want to network with.
June 05, 2014, 04:58:21 PM
xo4001
« Reply #6 on: June 05, 2014, 04:58:21 PM »
Salt, Bob,
Thanks for the input and link
Send the question to Koden wait and see what they come back with if any
H254
2 X Merc 115 4s
June 06, 2014, 11:35:26 AM
SaltH2OHokie
  • Mid Atlantic
« Reply #7 on: June 06, 2014, 11:35:26 AM »
I'm with ya Bob.  The Garmin puck I bought was a GP17 followed by some letters if I remember correctly. Fed a Furuno, a S-H and a Garmin.  I didn't even think twice about brands...reckon I was fortunate that my setup meshed.
Ryan
June 07, 2014, 11:20:11 AM
xo4001
« Reply #8 on: June 07, 2014, 11:20:11 AM »
Just get a reply from Koden what is now Si Tex
You can shorten the wire but may have to do some adjustments to trigger delay (timing) for accurate target distance but that should be it.
Yes you can use a puck antenna as long as it outputs NMEA 0183.
So all seems to be very simple :cheers:
H254
2 X Merc 115 4s
June 07, 2014, 12:19:48 PM
« Reply #9 on: June 07, 2014, 12:19:48 PM »
I'd go with a Garmin puck...
June 07, 2014, 12:33:02 PM
xo4001
« Reply #10 on: June 07, 2014, 12:33:02 PM »
Looking at this one
Garmin GPS 19x HVS Receiver NMEA 0183
What you think?
H254
2 X Merc 115 4s
June 07, 2014, 01:22:37 PM
« Reply #11 on: June 07, 2014, 01:22:37 PM »
Fine by me.  Looks like GPS City has it for $166, free shipping...http://www.amazon.com/Garmin-Next-Gener ... B0089YMO76
