Author Topic: Rusty eye removal?  (Read 397 times)
May 25, 2014, 05:36:55 PM
Read 397 times
Rusty eye removal?
« on: May 25, 2014, 05:36:55 PM »
Port side of my 222 on the transom. Very, very rusted especially on the inside of the transom. I do have some access from inside the port transom box. I can get a wrench on it but I don't think I will ever get it to turn. It has been PBd for a week.
Any ideas? I am thinking sawzall but I don't know if I can get it in there. Next choice is a hacksaw.
You can see it on the left of this pic, it is getting more and more rust draining down everyday.
May 25, 2014, 05:52:55 PM
Re: Rusty eye removal?
« Reply #1 on: May 25, 2014, 05:52:55 PM »
Cut-off wheel, Lewis.  Cut the U portion off at the top of the jam nuts.  Back the nuts off, then poke each of the shanks through the holes from the outside...easy peasy...
May 25, 2014, 08:00:44 PM
gman 82 aquasport
« Reply #2 on: May 25, 2014, 08:00:44 PM »
Seabob's right on the spot with this one :thumright: Had the same issue on mine at the beginning of the rebuild. Just used a cut off wheel and I then crosshaired the left over piece as I had a nut on the outside as well, cross hair cutting let the nut break off the left over piece, then just punch the rest to the inside :thumright: Might want to keep a spray bottle of water near it to keep the hull cool as I'm sure you don't want to re-paint the area :salut:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
