Hi Bob
I have the engine on a stand in my garage with a flush tank below the outdrive so I don't really have a key switch or any of the other normal wiring or gauges.
The wiring harness looked like it was ripped out when I got the boat, nothing connected, so I just did my best to label the loose wires.
I connected the main starter 12v+, starter Ground, Red 12v for Ignition (powerpack power?), Black for harness Ground (powerpack ground?), and Yellow with Red to a momentary switch for the Starter (makeshift key).
When testing the Purple wire it runs my electric fuel pump. The Purple with White wire turns on the Fuel Primer.
Maybe the powerpack is bad that's why I'm not getting spark?
If the lanyard switch wire is cut then it should be open and not grounding preventing power to the coil?
My manual has 2 different schematics I'm going off and they both show a "cut-off switch." Schematic 1 above is confusing me with all the parts attached to the brown wire circuit.
Steve
