Author Topic: Trailer Newbie Tire question  (Read 455 times)
May 17, 2014, 06:47:28 AM
Read 455 times
puff tentacle
« on: May 17, 2014, 06:47:28 AM »
I bought 17ft 85 Osprey and used to borrow a friends trailer when needed(only to launch and take out at seasons end)  I was given a trailer that needed TLC  put new hubs and bearings on the existing tiers and realized that one tire is not holding air die to a bent up rim.   My question is the tire size of these are 215/75-14,  am I limited to that tire size or can I go with lets say 205/75-14.   Thanks much :scratch:
May 17, 2014, 07:32:45 AM
Re: Trailer Newbie Tire question
« Reply #1 on: May 17, 2014, 07:32:45 AM »
No, you're not limited.  You can step down in cross section, but do both tires.  Don't just replace the 1 tire.
May 17, 2014, 07:38:42 AM
puff tentacle
« Reply #2 on: May 17, 2014, 07:38:42 AM »
Thank you, but what do you mean by cross section...something with the bolt pattern?
May 17, 2014, 09:49:25 AM
dburr
« Reply #3 on: May 17, 2014, 09:49:25 AM »
The first number is the cross section, I think it is in mm.. Google will set you straight.  Good luck!
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
May 17, 2014, 12:18:49 PM
« Reply #4 on: May 17, 2014, 12:18:49 PM »
215- width of tread in mm (cross section)
75-  sidewall aspect ratio
14-  rim diameter
May 17, 2014, 04:03:53 PM
puff tentacle
« Reply #5 on: May 17, 2014, 04:03:53 PM »
You the man, thank you
